ps3 errors
  • tamgunner
    • 691
    ps3 errors
    hi guys need your help just got a ps3 and its not reading any type of disc and it doesnt see my ethernet cable its plugged into the ps3 and the belkin router but ps3 says its not connected?
    any ideas where to start?
  • andy1weir
    • 363
    do the activity lights flash on the ethernet socket when you plug cable in??
    also how old is the ps3? usually when it doesnt see any games or stops reading them it means the laser has gone in your drive , or possibly the whole drive.
    • tamgunner
      • 691
      didnt notice the activity lights flash the router did flash a couple of times.
      not sure how old it is all it says on it is date code 7a.
      • andy1weir
        • 363
        have you tried using wireless?
        also did you buy it brand new? or was it a preowned console?
        • andy1weir
          • 363
          also the date code "7a" means it was manufactured in the first qurter of 2007 so either jan/feb/march so it could well be the laser has gone
          • tamgunner
            • 691
            i tried the wireless but it couldnt find my router or modem. bought it second hand.
            • andy1weir
              • 363
              it may be goosed then m8, the drive will deffo be down to the age of the console, but the ethernet one is new to me, you should maybe try seeing if theres any software updates available for it, download them from sony onto a flash drive then install from there
              • tamgunner
                • 691
                i checked the drive it accepted the disc but doesnt spin the disc is that the laser or something else?
                • andy1weir
                  • 363
                  copied this off another forum m8
                  i have now had quite a few of these come to me , the icon for reading is there , but you get no drive icon to choose at all , it will not recognise any disak at all and will not give any error message
                  Also if you listen , the drive is not spinning at all
                  there are four things which could be wrong
                  firmware update has shagged it (did this to my own jap ps3 , no fix I know of yet) everything is ok though just a firmware issue
                  The spindle drive is stuffed (unlikely but have seen just the one) , test it on an independant psu or batteries)
                  the laser controller chip is dead , yes guys the dreaded BA/LA is back with the PS3 , I have repaired a few of these the chip to look for is BD7956FS
                  and also the laser itself could have fried , now i have no idea why this is happening also after f/w updates , but have had a few machines that have died after playing cod4 , they do the update , play the game , switch the machine off , and next time they try to play nothing .Replacing the laser has worked on some but not all machines , maybe about 40%
                  so i would say its your laser which you can replace yourself, just get one off ebay but make sure it matches the one in your system
