HDMI not working, any ideas?
  • drake26
    • 6
    I have a 60gb PS3 and when i connected the HDMI it wont show up on the screen but its all fine with the RGB.
    It says HDMI detected would you like to use this.
    Then I clicked ok, switched to the HDMI and theres nothing on the screen.
    I am using a Sony Bravia if anyone can help it would be much appreciated.
    Thanks in advance
  • andy1weir
    • 363
    not sure if this would be much help m8 but i remember reading a while back that lots of people had problems hooking ps3's upto sony bravia tv's seems to be a kinda common problem
    • owenb
      • 703
      have u held the power button for 5 secons to get it to automatically detect when u turn console on???
      • punkmuffin
        I had the same problem with my 120gig would stopped working on HDMI called Sony they said it was Knackered and sent a replacement...if it is still under warranty call Sony
        • drake26
          • 6
          I have read about this aswell I was hoping if someone else knew how to solve it because ive been searching and cannot seem to find a solution. Sounds a bit stupid that sony tvs and ps3s are not compatible
          Tried it a few times just get a black screen on HDMI
          I am hoping this is not the problem, the warranty seal is intact so I have heard Sony can replace it but I have to pay them because its over a year old
          • cgscott
            • 3513
            Try hooking it up HDMI to another TV by doing the 5 second reset Video trick.
            If it works on that TV then its not compatible on your Bravia.
            Patience is a virtue.
            • ruben_17non
              • Jul 2010
              • 35
              +1 reset
              happened to me long ago, I did a reset and it worked
              • drake26
                • 6
                tried it on my dads tv only thing is thats a bravia aswell so it doesnt rule the compatibility issue out and i dont have any others to try it on
                • gtpilot
                  • Feb 2010
                  • 36
                  Perhaps :
                  Does your TV support 1080p? if not if I remember correctly you need to adjust the output display mode to match your tv which you should be able to do with RGB connected(Depending on how old the Bravia is it may only be 720p or 1080i).
                  • nicolas49250
                    I have got the same problem with my ps3 slim 120go and a bravia 32p3000 last month!
                    I buy an other HDMI cable and it works perfectly now!!
                    The seller tell me that it happen sometimes...
                    Try it first!!
                    • R18A
                      • 5
                      Just hold the power buttom then PS3 will automatic find your HDMI connection.
                      • rogermcgomry
                        • Feb 2010
                        • 30
                        You could also go through the settings using an output that works to manually change the output to HDMI.
                        • drake26
                          • 6
                          Originally posted by gtpilot
                          Perhaps :
                          Its a pretty new one and I cant get to those settings untill it detects the HDMI
                          Try it first!!
                          Ive used the HDMI I used in the previous model Bravia I had and the one from my Xbox and have had no luck
                          Tried it a few times I just get a black screen
                          Tried that too and I get a black screen
                          I just want to make sure I'm not missing something or doing something wrong before I decide to put the money down and send it off to Sony
                          I really appreciate the advice, I have the KDL-52W5000 I think thats the model number, my dads one I've also tested it on is a similar model from the same range just has lower specs
                          • tshirtman
                            • 1345
                            It sounds like a handshake problem, try this
                            turn your PS3 on using HDMI cable(and leave on), then unplug your T.V, leave the T.V off for 30 secs, then plug back in, this method works when your getting no sound. so might work, also
                            have you checked all your firmware is up to date, PS3, and T.V(if possible)
                            !retupmoc eht ni deppart m'I !pleH
                            • drake26
                              • 6
                              Didnt work PS3 and TV are up to date, after i did this it would not show up on the AV cable for a while either until i restarted it a few times
