PS3 YLOD BGA FIX
  • yysnet
    • Jul 2010
    • 36
    PS3 YLOD BGA FIX
    It's my friend's PS3, very old one... I fixed hundreds of 360s and this is my first time on PS3.
    If you press ON then it beep three times and led become yellow, then become red flashing...
    This fixed by reballing the GPU.
    I have lots of picture on the progress, but due to the picture limite only some are shown here:
    Put it to BGA rework station, and start to heat up to 220 degrees...
    Take off GPU
    Clean the remaining solder and flux (if there are any)
    Remove the remaining solder
    Put balls on a stencil
    Use hotair gun, heatup, then balls will be soldered to the GPU. Now GPU is fully prepared.
  • killersla
    • 79
    that stencil you use mate, so you leave that on and use a hot air gun to bond the balls to the chip first then back on the board.
    Also how are you using the stencil have you got some kind of rig?
    Im in the process of trying this for the xbox but having a bit of trouble using my stencil and rig.
    Could you mabe post a link to where you got the stencils from?
    • yysnet
      • Jul 2010
      • 36
      m8 you need to leave the stencil on until the balls are soldered to the GPU. These stencils should be available from ebay or anywhere else. There are basically two type fo stencil, direct heated or indirect heated.
      My stencil is directed heated one, so i just put everything on a wood and use hotair gun to boun the balls then just carefully remove the stencil. Hope this helps you.
      • killersla
        • 79
        ok thanks but how are you using your stencil to put the balls in?
        have you got some kind of rig or do you just shake the balls onto the stencil. I have got a spring loaded rig im using at the mo but im finding it hard to use properly.
        • yysnet
          • Jul 2010
          • 36
          I have no rig, just pour the balls on and use a paper to scratch them flat. This is tricky and needs more practice.
          • georgegt
            • Apr 2010
            • 179
            First time when a rebuilb the balls it was a flash for nokia 3310 and i try it for mor then 10 times to bee good
            • yysnet
              • Jul 2010
              • 36
              Agreed. Practise makes perfect anyway.
              • VDO
                • 400
                Hi
                Tell me friend what balls i need to bay for GPU and CPU i think to bay these in 0.60 mm is that good ?? Where to buy cheapest 20000-PCs-Soldering-Balls buy cheapest 20000 PCs Soldering Balls from china soldering tools wholesaler and dropshipper
                • deffc0n
                  • Aug 2009
                  • 894
                  Yes is good.
                  • dave11674
                    • 2025
                    hi
                    also after you clean the GPU are you repasting it ? before you apply the balls ?
                    i mean are you puttign any solder paste thru the stencil holes then pushing the balls into the paste then heatign to bond ?
                    #dave
                    Tools owned.
                    AVDI commander.
                    Dashfixer orig.
                    Dashfixer clone.
                    Fiat km tool.
                    Opel km tool.
                    Ford KM tool.
                    Op--com colne.
                    Lexia & PP clone.
                    Smok PSA, volvo & ford
                    If someone helps you DONT FORGET TO SAY THANKS its only polite....
