hi all i was trying to update the ps3 firmware from a usb stick it downloaded fine but it gets to 72% then stops. when i restart it starts again how can i get back to the menu?
ps3 stuck in update loop
You could try the recovery menu:
1. Turn off Playstation3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
I think option 5 is 'rebuild database' this will rebuilt the dashboard from the current firmware.
Or try and update the firmware from there. -
tried that but couldnt get to bring up the recovery menu!You could try the recovery menu:
Or try and update the firmware from there.Comment
i can download it ok but when i go to update it on the ps3 it starts then gets to a certain point and gives me an error and wont update. i cant even get the recovery menu unless i plug the hd into my pc and format it then plug it back into the ps3Comment
