ps3 jail break explained
  • killersla
    • 79
    people are looking for a easy tut to follow for installing the ps3 jail break well here we go. please note this is not my work im just compiling from other sites.
    to buy these Max AVR USB i recomened you go to this site. I also might add it is team xecuter who sourced most of these chips for resale.
    AVR USB Kits - CK3.CO.UK
    edit: i have now added a pdf at the bottom of the post with clear instructions on how to flash the usb drive ready to use
    Index
    1. Introduction
    2. Packaging
    3. The Chip
    4. Requirements
    5. Installation
    6. Usage
    7. Our tests
    8. Conclusion
    1. Introduction
    Here it is, one of the first AVR USB out on the market that is designed and manufactured on the USA/EU.
    Official Product Description:
    The Max AVR USB board is a low-cost demonstration board based on the AT90USB 16kb microcontroller. It allows the quick evaluation of AVR microcontrollers and the AT90USB family.
    The key simply plugs into the USB port of a personal computer. Designers can either run demonstration programs or their own application. Using the ATMEL FLIP Software.
    2. Packaging
    The chip comes packaged on a purple bag, with its geniune sticker glued up. After opening the package we found out our first impression with this AVR. We were told that these first batch
    will come without housings, however in the near future they will be bundled with a housing to protect our investment. For now at least the chip comes sealed with a plastic protection to prevent
    electric shorts if it gets on contact with any conductive surface.
    3. The Chip
    This little AVR is based on the AT90USB microcontroller. Keep in mind that the chip sold as is wont work to put our PS3 on dev mode, at least not until the proper HEX has been flashed onto
    the AVR. The design of these AVR is well known and not a non-standard one, which helps for the porting of the PSGroove onto it or flashing utils. For flashing the hex we need an Atmel software named
    FLIP which is available for free
    4. Requirements
    Ok so now were gonna focus on getting this product to work on our beloved PS3. To start this is what is needed:
    Hardware
    - PS3 FAT/SLIM (Duh!)
    - PC/Laptop to flash the Max AVR the first time
    - One original PS3 Game (if you want to test the Backup Manager)
    - Free space on Internal/External HDD on the PS3 if plan to use with Backup Manager
    Software
    - PS3 OS 3.41 or lower installed (if your 3.42 your out of luck)
    - PC OS Windows (had some issues with 64bits OS for flashing the AVR, so I recommend 32bit)
    - Atmel FLIP 3.4.2 (To flash the AVR. Grab it here Atmel - Page Not Found)
    - A working hex file to flash it with ( check Maximus AVR Tutorials )
    5. Installation
    Our first step to get the unit working is doing the flash of the hex. I'll try to sumarayze the steps.
    - Install the Atmel FLIP Software
    - Connect the AVR on the PC
    - Press both buttons on the AVR (RST HWB)
    - Release the RST button, then the HWB
    - Windows should ask for drivers of the new hardware found. Point them to C:\program files\atmel\flip 3.4.2\usb
    - Run FLIP, and flash with the correct hex
    If you want more details on the flasshing I recommend you visit this blog Maximus AVR Tutorials
    6. Usage
    The AVR should be programmed with the PSGroove by now, so its time to put it to work. To do so, the first step we need to do is be sure that no other usb device is attached to the PS3.
    Verify that the Max AVR should be connected on the first port on the front of the PS3. The unit must have been cold booted (PS3 Fats, move the on/off switch from the back, and PS3 slims
    would need to have the power cord disconnected/connected). After that, we need to turn on the PS3, and just after hitting the ON button, we need to press the EJECT button.
    After a few seconds, first the AVR will lit up a red led, and after 1 or 2 seconds more, it will change to green. Once it changes to Green it means that the exploit was succefully done.
    Congratulations, now you have a PS3 running on DEV mode If you want to install ipk packages (ie ps3 ftp server or bacukp manager) you need to copy the files onto a usb mass storage device,
    and you will be able to install them from the Game menu inside the PS3.
    Here is a small video showing how to boot up the ps3
    [ame=http://www.youtube.com/watch?v=RpvTJYY_EnQ]YouTube - Sample video of MAX AVR USB booting procedure w/ PSGroove[/ame]
    7. Our tests
    With 24 hour of testing, the game compatibility was exactly the same as the PSGroove. I suggest you check this table before doing your backups to see if there arent any known issues of it.
    8. Conclusions
    After playing around 1 day with this AVR, I must say I was excited to see a PS3 see the light of the day. I really want to see what open source projects can come to life onto the PS3 with
    the amount of processing power the PS3 has
    Pros:
    + Price
    + Uses open source project for its code, making it a safe product
    + Easy operation
    + No opening of the PS3 required
    + Updateable
    Cons:
    - Backup Managers from other products (ie PSJailbreak 1.1) might not directly work on this (until some clever guys find a way to patch from PSGroove/Binary to emulate/crack it)
    - Earliers adopters of this AVR might not get a housing
  • akhlaq768
    • 196
    shoul be made a sticky
    • PAUL7331
      • 163
      Ok, on the site on the sticky it says IN STOCK. But is this a definate mate? As some sites take your money and then email you to say 'out of stock'
      • killersla
        • 79
        if you are un sure about any thing then email the web site first. May I add this is a xecuter official reseller I have bought off them plenty in the past they are very good and if it says IN STOCK then I would presume that they are.
        • reddevil157
          • 1427
          Would I be right to assume that when minimus is plugged into computer, so, we're looking at it from the led end, button on the left is reset, button on the right is hwb, whatever that means ?.
          9. If you need to re-program the Minimus then putting it into DFU mode for programming
          is very easy:
          a. Plug the Minimus into the USB port of your PC.
          b. Press and hold the RESET button.
          c. Press and hold the HWB button.
          d. Release the RESET button.
          e. Release the HWB button.
          f. That's it - now you are ready to program with Flip
          Ok, think I got it.
          • hawk188
            • Oct 2010
            Thanks.Good post !
