newbie to ps3 hacking
  • leeunwin
    • 269
    ok so ive got a soft modded wii that i did myself easy enough
    also psp modded with newest firmware did myself
    also a xbox 360 flashed did myself
    so how easy is it to jailbreak a ps3 with a iphone
    also once done and you have backup manager on ps3 itself ect...
    can you add a external hardrive to put the games on and play directly from that and do i need the original in the bluray drive
  • Mjolinor
    V.I.P. VIC
    • 1093
    I wouldn't bother with the Iphone it's too much hassle. It takes it several minutes to boot and you can only get the PS3 into the correct mode once and then you have to reboot it. There is also no indication that it did its job.
    Last time I tried was a month or so ago, maybe things have changed but it really is so much easier to get a dongle, they only cost ?5 or so from China.
    • leeunwin
      • 269
      ok cheers for info over iphone hacking
      what about this ftp thing ive got the client on pc for it and i no u have to install it on ps3
      wont i dont get is is there a way to transfer games instead of downloading to my pc harddrive then across to ps3 via ftp..?
      • Mjolinor
        V.I.P. VIC
        • 1093
        The FTP server for the PS3 has to be installed on the internal hard disk of the PS3 and appears as a game once the PS3 is booted with the dongle. Once rrun on the PS3 you can connect to it with the client from your PC should you want to transfer files that way. If you have the original CD / DVD / blu ray game then you can copy that directly to the internal hard disk of the PS3 with the file manager that you will install once you get it booted or you can stick the game on a USB stick / disk and plug that in the PS3.
        As far as I know these are the only ways to get games onto the PS3.
        • leeunwin
          • 269
          so can i put a game in my pc drive copy it over to a usb flash stick and copy that to ps3?
          • leeunwin
            • 269
            ok so i can put a ps3 game in ps3 and copy that straight onto my hard drive ? will the disk still need to be in the bluray for me to play it
            • Mjolinor
              V.I.P. VIC
              • 1093
              Yes
              No
              Gese this minimum message length does cause problems to lazy gits like me.
              • leeunwin
                • 269
                whats best site and cheapest to order the usb jailbreak dongle
                • leeunwin
                  • 269
                  also wich dongle is the best to use
                  • leeunwin
                    • 269
                    also to use the backup manager what firmware must the ps3 be running can it only work with 3.4.1?
                    • leeunwin
                      • 269
                      does it need to be 3.4.1 are can it be any lower eg.. aslong as its not above 3.4.1 as im finding it really hard to find a ps3 running 3.4.1
                      • dik
                        • Apr 2009
                        • 955
                        Ebay is worth a look
                        search for minimus 32 avr
                        to jailbreak a ps3 the firmware must be 3.41 or lower
                        some games will need higher firmwares to run, so unless you need to keep linux update it to 3.41, all newer games will need 3.50 to work so as yet you will not be able to play gt5 etc.
                        You can get 3.41 firmware HERE
                        sigpic another happy customer
                        Sent from my keyboard using fingers to type
                        • leeunwin
                          • 269
                          cheers
                          thanks alot for replying mate top lad
                          • Oily
                            • Apr 2009
                            • 123
                            USBBreak dongle will fool your 3.41 PS3 into thinking it's running 3.5
                            Buy USB Break For PS3 [FREE SHIPPING] [usbbreak] - $17.50 : USB-BREAK.COM
                            • titch39
                              • 9
                              i used E3 card which now spoofs 3.55 firmware and can downgrade your ps3 too. e3 card reader, new generation ps3 chip with mulit-function
                              upgraded internal hard drive to 500 gigs and all is great
