TROUBLE INSTALLING NEW HDD
  • roryson
    • Mar 2009
    • 694
    Just got through the post my new HDD for the PS3. its a Samsung 640GB 5400rpm. it was rocommended to me in another post. So swapped the drives over after a backup. powered the PS3 up and i get a message saying connect the controller using a USB cable, after that i get another msg saying turn off the computer. and this cycle repeats.. ANY IDEAS people.. Thanks in advance... a confused guy...
  • allycoops
    • Feb 2008
    • 1075
    I have the same drive and recommended it to you mate,
    All I done was plug the drive in. connected a ps3 wireless controller via a usb port with cable and formatted the new drive, restarted ps3 no problems at all
    so after you connected the ps3 controller have you formatted the new drive royston?
    Let the others come after us, We welcome the chase
    • roryson
      • Mar 2009
      • 694
      dont get to the format screen mate
      • allycoops
        • Feb 2008
        • 1075
        Is this the error youre getting royston
        The system software cannot be run correctly. Press the PS button to try to restart the system.
        If the system cannot be restarted, the system partition of the hard disk must be reformated and you must install the system software. Insert storage media that contains update data of version 2.30 or later, and then press the START and SELECT buttons at the same time.
        For information on how to obtain update data, refer to the SCE web site for your region
        • roryson
          • Mar 2009
          • 694
          1 min, ill try again..
          it says do data can be found
          • roryson
            • Mar 2009
            • 694
            i connected the external HDD i backed up my system with
            • roryson
              • Mar 2009
              • 694
              am i right in thinking i need to download update softwear from sony sight and put it on my external HDD..?
              • allycoops
                • Feb 2008
                • 1075
                Have a read of this it may help you Bud.
                Playstation 3 hard drive replacement info.
                • roryson
                  • Mar 2009
                  • 694
                  just downloaded the latest software update 3.55. am i right in thinking that to solve my problem. insert the new drive into PS3, load my USB dongle with the latest software update and install the update from there... any ideas..??
                  • allycoops
                    • Feb 2008
                    • 1075
                    I wouldn't install 3.55 mate, what firmware were you on previously? if you want to hack your ps3 you want to install 3.41 firmware.
                    • allycoops
                      • Feb 2008
                      • 1075
                      There's a webpage that has all the firmware listed on , (sorry I can't find it at the moment) but you need to download the 3.41 update (don't download any higher version if you want to hack PS3)
                      If you can't find it let me know , I have it somewhere on my pc upstairs and will upload it for you. 3.41 (2nd release) fixed an issue with new HDDs
                      • andy1weir
                        • 363
                        here is a webpage where you can download whichever firmware you want for it
                        PS3 Downloads - PS3 Firmware Updates
                        • roryson
                          • Mar 2009
                          • 694
                          not bothered about jailbreaking my PS at the moment, so think ill update with 3.55. have i got the right procedure fot updateing using flash file and a USB dongle...??
                          • andy1weir
                            • 363
                            ok m8 if your using 3.55 download that
                            on the root of your usb stick create a folder called PS3 (must be in caps) in that folder create another folder called UPDATE (again caps) then place the PS3UPDATE.PUP file that you downloaded in the UPDATE folder
                            so on your flash drive you should have PS3> UPDATE> PS3UPDATE.PUP
                            plug in your dongle to ps3
                            turn on ps3
                            it should come up saying something like ps3 cannot start or something but if you read it it should say press START and SELECT together, so do that then itll search for firmware on dongle, once found it will then begin to format then just follow the onscreen instructions
                            • roryson
                              • Mar 2009
                              • 694
                              spot on m8, clear instruction there. kinda late now but will give it a go tomorrow. thanks again mate..
