Custom firmware on Slim PSP
  • Erazor786
    • 55
    Hi all. I'm looking to downgrade a Slim PSP.
    I've done a fair bit of reading and understand that i need to create a Pandora bat and magic memory stick. I've got a piece of software called PSP Grader v005 posted by JTH which i understand is needed to create the Memory stick. IVe downloaded the Eboot for 1.5 and the official firmware update for 3.90 as ive read ive needed them.
    Just want to make sure I'm going in the right direction in regards to downgrade a SLIM psp. I understand that SLim psp's are not downgraded to 1.5 or something and are done in a different way.
    And also wanted to ask how do i create the Pandora battery as I've not found much info on that.
    Thanks all.
  • biffo1
    • 420
    some info for u mate
    Disinter
    Version: 3.80
    Released: 01/26/2008 (AUS DATE)
    Programmer: Klutsh
    Modifications: DJB
    License: GNU GENERAL PUBLIC LICENSE
    Copyright Notes: The Sony Firmware Updates are not included.
    *** USE OF THIS PROGRAM IS YOUR OWN RISK ***
    *** NEVER USE THIS TO CONVERT A SLIM BATTERY TO PANDORA! ***
    *** YOU WILL KILL YOUR BATTERY! ONLY USE WITH FAT'S BATTERY! ***
    Disinter is a .NET v2 application, it is used to copy applications and files to
    a PSP for use in making a "Pandora" MemStick for both the "Phat" & "Slim" PSP's.
    Features:
    - Either a 1.50 or 3.80 Firmware "Pandora" MemStick can be created.
    - Option to install the 1.50 Kernel extentions for M33-3.80 on a "Phat" PSP.
    - Loading of eBoots directly or from rar files.
    - Full onscreen instructions.
    - All features can be used on Vista.
    - MD5 verification of eBoot's.
    Updates:
    V3.80
    - Updated to use Despertar del Cementerio v4.
    (Installs M33-3.80-5)
    - Updated to use Hellcats Pandora Installer for 3.xx, V3a
    - Updated to use M33-3.80 1.50 Addon
    V2.2
    - Updated to use Despertar del Cementerio v3.
    (Installs M33-3.71-2)
    V2.1
    - Updated to use Hellcats Pandora Installer for 3.xx, V2b
    (Fix's some errors with the format and repartition)
    How to Use:
    See Usage in the Credits and Usage Tab.
    Notes:
    If your PSP Freezes after performing a Firmware restore, boot into recovery mode
    and format Flash1. This will clear all setting's and allow the PSP to boot.
    Dark Alex and the M33 Team, Hellcat.
    Requirements:
    Microsoft .NET Framework V2 capable OS
    PSP with 3.xx Custom Firmware.
    PSP "Phat" battery.
    if u want mate ill send u my bat and stick , then talk u through it
    all the best biffo
    [CENTERsigpic[/CENTER]
    • Erazor786
      • 55
      Thanks for the reply biffo m8.
      I understand that Disinter and the PSP Grader are the same things...?
      I have got a Phat PSP with custom firmware which i will be using to create the memory stick. I'm just not quite sure what i need to do to create the battery.
      When i install the needed files and create the memory stick, are the files needed to create the Battery on the memory stick.
      Just need help really sorting out the battery as i think ive got the memory card sorted.
      • kryton
        • 51
        Originally posted by Erazor786
        Thanks for the reply biffo m8.I understand that Disinter and the PSP Grader are the same things...?
        there is a slight difference between the 2 mate.
        psp grader formats and copys the files already created for pandora to your memory stick.
        it is aimed more at people who already have a pandora battery.
        disinter you have to run a few programs to create the memory stick and battery on your PSP.
        i would go with disinter mate (on your FAT psp) and follow the guide in this post: Digital Kaos - View Single Post - pandora's battery
        • Erazor786
          • 55
          Just wanted to say thanks alot Kryton for the helping hand, much appreciated.
          got it sorted, got a quick question, ive posted it somewhere else, but just in case.
          In the ISO folder there is another folder called video, what is that for ? can i get rid of it or shall i just leave it and ignore it?
          Thanks again for your help m8
          Rep Added
          • kryton
            • 51
            Rep Added
            the video folder is for mounting UMD films (ISO) mate.
            put the UMD ISO (film) in the video folder then mount it using the VSH menu.
