PSP wont turn on
  • cgscott
    • 3513
    PSP wont turn on
    Got a PSP (not slim) for my son. Was working then ran out of charge. Now it wont charge at all.
    No lights nothing.
    Any suggestions?
    Patience is a virtue.
  • RVP711
    Try using a battery that is already charged and see if it works.
    • mitin
      • 197
      try new battery
      • anonomus
        • 32
        try taking the battery out then in again i've had the same problem more than once
        A N O N O M U S
        • galinpizza
          • 10
          1.Charge PSP one night and try to turn it on
          2.Try to turn it on with other baterry
          • Millzzy
            • 119
            other thing it could be is power switch has gone knackered not a hard or expensive fix for a FAT psp ;-)
            • short360uk
              • 313
              sounds like the charger is at fault. a psp will work with no battery if the charger is plugged in
              • cgscott
                • 3513
                Ok guys just to let you know it was the internal charge port and the 2 amp fuse had blown inside.
                Also had a problem with the screen but all is sorted now.
