found online hope it helps some one as it did for me
== Introduction ==
Sometimes the PSP gives an error, but what does it mean? How to solve it?
On this page you'll find the information that you need:
== Normal errors ==
The first 4 numbers gives information about the place of the error:
8002XXXX = Kernel
8001XXXX = The standard libc
00000001
Internal Error
1. Reset your settings to default
2. Theres no WiFi point found
80020148
The game could not be started
If you're under an Official Firmware you can't run homebrew, downgrade/upgrade to an Custom Firmware.
8002013C
Error in the flash memory of the PSP.
Try to restore your flash0-backup or re-install the Custom Firmware.
80020321
Check if you configured kernel or UMD/ISO mode right.
8008273A
Internal Error
80108D50
PSP Camera not connected
80410A0B
Hardware Error
WiFi is damaged.
== IDstorage errors ==
DRNFFFFFFD8 = key 0x4 missing
DRNFFFFFFD7 = key 0x4 header is not "n y r B" (in hex: 6E 79 72 42)
DRNFFFFFFCE = key 0x5 missing
DRNFFFFFFCD = key 0x5 header is not "g k l C" (in hex: 67 6B 6C 43)
DRNFFFFFFC4 = key 0x6 missing
DRNFFFFFFC3 = key 0x6 header is not "r d D M" (in hex: 72 64 44 4D)
Errors with TA-086 PSP motherboards:
DRNFFFFFFB9 = key 0x7 header is not "D a P A" (in hex: 44 61 50 41)
DRNFFFFFFB0 = key 0x8 missing
DRNFFFFFFAF = key 0x8 header is not "p D C L" (in hex: 70 44 43 4C)
You can repair this with IdStorage Manager.
For key 08 errors make a new key 08 by adding this line:
"70 44 43 4C 01 00 00 00 0C 00 00 00 76 FC 19 C8 0A 00 19 00 10 00 0D 00 07 00 02" and than 00 untill the end.
CTA80000025 = region key (0x0100) is damaged or missing (You only can repair this with your OWN backup).
== Errorlist: ==
* UKN9000001 = The update cannot be started. The data is corrupted.
* 80110305 = Load failed.The [[Memory Stick]]? could not be acessed.
* 80010013 = device / media not found
* 8001B002 = unknown
* 80020001 or 800244C = kernel errors
* 80020001 = generic kernel error (default)
* 800200D9 = failed to allocate the memory block
* 80020130 = file read error
* 80020148 = PRX type unsupported
* 80110482 = occurs when test of WLAN infrastructure connection fails
* FFFFFED3 = unknown (might be decryption error)
* 80410001 or 80410D16 = network errors
* 80410D07 = unknown (possibly WLAN)
* ffffffff = PSP update failed
* 80410A0B = Internal Error
* 8041040F = DNS Error, unable to connect to server
* 80410410 = Cannot connect to the given acess point
* 80010087 = The game could not be started
* 0x0 = no error
* 0x80020001 = error
* 0x80020002 = not implemented
* 0x80020032 = illegal exception code
* 0x80020033 = exception handler not use
* 0x80020034 = exception handler already used
* 0x80020035 = system call table notuse
* 0x80020036 = system call table alraady used
* 0x80020037 = illegal system call table
* 0x80020038 = illegal Primary Syscall number
* 0x80020039 = Primary Syscall number already use
* 0x80020064 = call from interrupt handler/thread
* 0x80020065 = illegal INTRCODE
* 0x80020066 = CPU already interrupt disable
* 0x80020067 = Handler already exist
* 0x80020068 = Handler not found
* 0x80020069 = illegal interrupt level
* 0x8002006a = illegal address
* 0x8002006b = illegal IntrHandler Option Paramsize
* 0x8002006c = illegal stackad dress
* 0x8002006d = alreadystackad dressset
* 0x80020096 = not found free Hard Timer
* 0x80020097 = illegal timer ID
* 0x80020098 = illegal source
* 0x80020099 = illegal prescale
* 0x8002009a = Hard Timer in use
* 0x8002009b = Hard Timer not setup
* 0x8002009c = Hard Timer not in use
* 0x800200a0 = unit number already used
* 0x800200a1 = unit number notused
* 0x800200a2 = rom directory notfound
* 0x800200c8 = id type already exist
* 0x800200c9 = id type not exist
* 0x800200ca = {not available}
* 0x800200cb = unknown UID
* 0x800200cc = unmatch UID type
* 0x800200cd = id not exist
* 0x800200ce = not found UID function
* 0x800200cf = UID already holder
* x800200d0 = UID not holer
* 0x800200d1 = illegal permission
* 0x800200d2 = illegal argument
* 0x800200d3 = illegal adress
* 0x800200d4 = the memory area is out ofrange
* 0x800200d5 = the memory areais over lap
* 0x800200d6 = illegal partitionid
* 0x800200d7 = partition in use
* 0x800200d8 = illegal memory block allocation type
* 0x800200d9 = failed toal loca the memory block
* 0x800200da = inhibitedtores izethismemoryblock
* 0x800200db = failedtoresize thismemoryblock
* 0x800200dc = failedtoalloca teheapblock
* 0x800200dd = failedtoalloca teheap
* 0x800200de = illegalchunkid
* 0x800200df = cannotfindchun kname
* 0x800200e0 = thereisnofreec hunk
* 0x8002012c = modulelinkerro r
* 0x8002012d = illegalobjectf ormat(notPRX/PFX)
* 0x8002012e = notfoundModule
* 0x8002012f = notfoundModule file
* 0x80020130 = Modulefileread error
* 0x80020131 = memoryinuse
* 0x80020132 = partitionmisma tch
* 0x80020133 = modulealreadys tarted
* 0x80020134 = modulenotstart edyet
* 0x80020135 = modulealreadys topped
* 0x80020136 = modulecannotst op
* 0x80020137 = modulenotstopp edyet
* 0x80020138 = modulecannotre move
* 0x80020139 = exclusiveload
* 0x8002013a = Libraryisnotli nkedyet
* 0x8002013b = Libraryalready exists
* 0x8002013c = Librarynotfoun d
* 0x8002013d = illegalLibrary header
* 0x8002013e = Libraryisusedn ow
* 0x8002013f = modulealreadys topping
* 0x80020140 = illegaloffsetv alue
* 0x80020141 = illegalpositio ncode
* 0x80020142 = illegalaccessc ode
* 0x80020143 = modulemanagerb usy
* 0x80020144 = illegalflag
* 0x80020145 = cannotgetmodul elist
* 0x80020146 = prohibitLoadMo duledevice
* 0x80020147 = prohibitLoadEx ecdevice
* 0x80020148 = unsupportedPRX type
* 0x80020149 = illegalpermiss ioncall
* 0x8002014a = cannotgetmodul einformation
* 0x8002014b = illegalLoadExe cbuffer
* 0x8002014c = illegalLoadExe cfilename
* 0x8002014d = Thereisnoexitc allback
* 0x80020190 = nomemory
* 0x80020191 = illegalattrpar ameter
* 0x80020192 = illegalthreade ntryaddress
* 0x80020193 = illegalpriorit yvalue
* 0x80020194 = illegalstacksi ze
* 0x80020195 = illegalmode
* 0x80020196 = illegalmask
* 0x80020197 = illegalthreadI D
* 0x80020198 = notfoundthread
* 0x80020199 = notfoundsemaph ore
* 0x8002019a = notfoundeventf lag
* 0x8002019b = notfoundmessag ebox
* 0x8002019c = notfoundVpool
* 0x8002019d = notfoundFpool
* 0x8002019e = notfoundmessag epipe
* 0x8002019f = notfoundalarm
* 0x800201a0 = notfoundthread eventhandler
* 0x800201a1 = notfoundcallba ck
* 0x800201a2 = threadalreadyD ORMANT
* 0x800201a3 = threadalreadyS USPEND
* 0x800201a4 = threadisnotDOR MANT
* 0x800201a5 = threadisnotSUS PEND
* 0x800201a6 = threadisnotWAI T
* 0x800201a7 = nowdispatchdis abled
* 0x800201a8 = WAITtimeout
* 0x800201a9 = WAITcanceled
* 0x800201aa = WAITstatusrele ased
* N0x800201ab = WAITstatusrel easedwithcallback
* 0x800201ac = threadistermin ated
* 0x800201ad = semaphorecount erzero
* 0x800201ae = semaphorecount eroverflow
* 0x800201af = eventflagcondi tionnotoccur
* 0x800201b0 = thiseventflagc annotacceptwaitswithmulti plethreads
* 0x800201b1 = illegaleventfl agwaitpattern
* 0x800201b2 = messageboxhave nomessage
* 0x800201b3 = messagepipeisf ull
* 0x800201b4 = messagepipeise mpty
* 0x800201b5 = waitobjectdele ted
* 0x800201b6 = illegalmemoryb lock
* 0x800201b7 = illegalmemorys ize
* 0x800201b8 = illegalscratch padaddress
* 0x800201b9 = scratchpadinus e
* 0x800201ba = scratchpadnoti nuse
* 0x800201bb = illegaltype
* 0x800201bc = illegalsize
* 0x800201bd = illegalcount
* 0x800201be = notfoundvtimer
* 0x800201bf = illegalvtimerI D
* 0x800201c0 = illegalKTLSID
* 0x800201c1 = KTLSisfull
* 0x800201c2 = KTLSisbusy
* 0x80020258 = invalidsuchpri ority
* 0x80020259 = devicenameisin valid
* 0x8002025a = devicenameisun known
* 0x8002025b = pminformationi sregisteredalready
* 0x8002025c = pminformationi snotregistered
* 0x8002025d = majorstateisin validvalue
* 0x8002025e = requestisinval id
* 0x8002025f = requestisunkno wn
* 0x80020260 = unitnumberisin valid
* 0x80020261 = cannotcancelre quest
* 0x80020262 = pminformationi sinvalid
* 0x80020263 = argumentisinva lid
* 0x80020264 = alreadytargete powerstate
* 0x80020265 = failedtochange systempowerstate
* 0x80020266 = cannotchangede vicepowerstate
* 0x80020267 = devicedoesnots upportsuchpowerstate
* 0x800202bc = requesttotheDM ACfailed
* 0x800202bd = DMAoperationis lessorequalone
* 0x800202be = theoperationis alreadyqueued
* 0x800202bf = theoperationis alreadyfinishedornotqueue ud
* 0x800202c0 = theoperationis alreadyintransferprogress
* 0x800202c1 = theoperationis notassignedyet
* 0x800202c2 = thesyncoperati ontimedout
* 0x800202c3 = dmaoperationst ructisalreadyfreed
* 0x800202c4 = dmaoperationis used
* 0x800202c5 = dmaoperationis empty
* 0x800202c6 = DMAoperationis aborted
* 0x800202c7 = DMAoperationis error
* 0x800202c8 = physicalDMAcha nnelisalreadyreserved
* 0x800202c9 = physicalDMAcha nnelisnotmanagedbydmacman ager
* 0x800202ca = thereisaprivil egeaddressinlinklist
* 0x800202cb = linklistbuffer isnotenough
* 0x800202cc = theoperationis notassignedtophysicalDMAc hannel
* 0x800202cd = theoperationis childoperation
* 0x800202ce = itistoomuchtha ntransferabledatasize
* 0x800202cf = argumentisinva lid
* 0x80020320 = Toomanyopenfil es
* 0x80020321 = Nosuchdevice
* 0x80020322 = Cross-devicelink
* 0x80020323 = Badfiledescrip tor
* 0x80020324 = Invalidargumen t
* 0x80020325 = Unsupportedope ration
* 0x80020326 = Aliasisalready used
* 0x80020327 = Cannotmount
* 0x80020328 = Driverdeleted
* 0x80020329 = Asyncoperation isbusy
* 0x8002032a = Noasyncoperati on
* 0x8002032b = Deviceisalread yregistered
* 0x8002032c = Nocurrentworki ngdirectory
* 0x8002032d = Filenametoolon g
* 0x800203e8 = DECI3Nosuchdev iceoraddress
* 0x800203e9 = DECI3I/Oerror
* 0x800203ea = DECI3Notenough core
* 0x800203eb = STDIOnotopened
* 0x8002044c = Parameterisnot cachealigned
* 0x8002044d = Endofkernelerrorcode.Neverusethisname
* CA000005 - keys.bin not found when trying to run a PS1 game.
* DADADADA - Running a FW Update in DAX custom FW
* FFFFFFFF - PSP update failed
* UKN9000001 - update cant start, data corrupt
* 00000001 - WiFi error. Occurs when no access points are detected in official 3.7X and custom 3.7X firmware.
* 80010087 - Error reading UMD or UMD not present
* 80110305 - Load failed.The [[Memory Stick]] could not be acessed
* 80020148 - Unsupported PRX type | This error also seems to appear when you are running an iso with a [[Fake Memory Stick|fake mem. stick]]
* 8001006F - [[Remote Play]] connection error. Most likely when no PS3 is sending a signal over your network.
* 800200D1 - Ran homebrew without Homebrew enabled firmware.
* 8002014C - Ran kxploited homebrew without Homebrew enabled firmware.
* 80020321 - Ran a game that doesn't support NO-UMD* (DAX FW ONLY!)
* 80110404 - Network error, try restore default settings to fix
* 80000004 - its just a general error code that the PSP spits out when it doesnt understand something could mean anything
* 80110307 - Load Failed There is no Data available
* 80010002 - Putting the POPS EBOOT in the wrong folder
* 80000001 - Got it when trying to run PSP filer version 3.6 on 3.40* firmware
* 80410A0B - Loose WiFi card
* 80020321 - No umd in drive when no umd is disabled
* 80110305 = Load failed.The [[Memory Stick]] could not be acessed
* 80020321 - No umd in drive when no umd is disabled / Ran a game that doesn't support NO-UMD / "No-UMD Mode"
* 98765432 - Selected a language who's font has been removed. DAX FW ONLY ERROR!
* 80020148 - (unsupported PRX type)?
* 800201A8 - (WAIT timeout)?
* 80020130 - File Read Error (ex. length is 0)
* 80020001 - Generic Kernel Error - default (ex. executable is invalid)
* 800200D9 - Failure to allocate memory block (ex. missing PSP)
* 80410D07 - Connection error has occurred. (Ie cant find access pt)
* 80020001 - error
* 80020002 - not implemented
* 80020032 - illegal exception code
* 80020033 - exception handler not use
* 80020034 - exception handler already used
* 80020035 - system call table not use
* 80020036 - system call table already used
* 80020037 - illegal system call table
* 80020038 - illegal Primary Syscall number
* 80020039 - Primary Syscall number already use
* 80020064 - call from interrupt handler/thread
* 80020065 - illegal INTRCODE
* 80020066 - CPU already interrupt disable
* 80020067 - Handler already exist
* 80020068 - Handler not found
* 80020069 - illegal interrupt level
* 8002006a - illegal address
* 8002006b - illegal Intr Handler Option Param size
* 8002006c - illegal stack address
* 8002006d - already stack address set
* 80020096 - not found free Hard Timer
* 80020097 - illegal timer ID
* 80020098 - illegal source
* 80020099 - illegal prescale
* 8002009a - Hard Timer in use
* 8002009b - Hard Timer not setup
* 8002009c - Hard Timer not in use
* 800200a0 - unit number already used
* 800200a1 - unit number not used
* 800200a2 - rom directory not found
* 800200c8 - id type already exist
* 800200c9 - id type not exist
* 800200ca - {not available}
* 800200cb - unknown UID
* 800200cc - unmatch UID type
* 800200cd - id not exist
* 800200ce - not found UID function
* 800200cf - UID already holder
* x800200d0 - UID not holder
* 800200d1 - illegal permission
* 800200d2 - illegal argument
* 800200d3 - illegal address
* 800200d4 - the memory area is out of range
* 800200d5 - the memory area is overlap
* 800200d6 - illegal partition id
* 800200d7 - partition in use
* 800200d8 - illegal memory block allocation type
* 800200d9 - failed to allocate memory block
* 800200da - inhibited to resize this memory block
* 800200db - failed to resize this memory block
* 800200dc - failed to allocate heap block
* 800200dd - failed to allocate heap
* 800200de - illegal chunk id
* 800200df - cannot find chunk name
* 800200e0 - there is no free chunk
* 8002012c - module link error
* 8002012d - illegal object format (not PRX/PFX)
* 8002012e - not found Module
* 8002012f - not found Module file
* 80020130 - Module file read error
* 80020131 - memory in use
* 80020132 - partition mismatch
* 80020133 - module already started
* 80020134 - module not started yet
* 80020135 - module already stopped
* 80020136 - module cannot stop
* 80020137 - module not stopped yet
* 80020138 - module cannot remove
* 80020139 - exclusive load
* 8002013a - Library is not linked yet
* 8002013b - Library already exists
* 8002013c - Library not found
* 8002013d - illegal Library header
* 8002013e - Library isused now
* 8002013f - module already stopping
* 80020140 - illegal off set value
* 80020141 - illegal position code
* 80020142 - illegal access code
* 80020143 - module manager busy
* 80020144 - illegal flag
* 80020145 - cannot get module list
* 80020146 - prohibit Load Module device
* 80020147 - prohibit Load Exec device
* 80020148 - unsupported PRX type
* 80020149 - illegal permission call
* 8002014a - cannot get module information
* 8002014b - illegal Load Exec buffer
* 8002014c - illegal Load Exec file name
* 8002014d - There is no exit callback
* 80020190 - no memory
* 80020191 - illegal attr parameter
* 80020192 - illegal thread entry address
* 80020193 - illegal priority value
* 80020194 - illegal stack size
* 80020195 - illegal mode
* 80020196 - illegal mask
* 80020197 - illegal thread ID
* 80020198 - not found thread
* 80020199 - not found semaphore
* 8002019a - not found event flag
* 8002019b - not found message box
* 8002019c - not found Vpool
* 8002019d - not found Fpool
* 8002019e - not found message pipe
* 8002019f - not found alarm
* 800201a0 - not found thread event handler
* 800201a1 - not found callback
* 800201a2 - thread already DORMANT
* 800201a3 - thread already SUSPEND
* 800201a4 - thread is not DORMANT
* 800201a5 - thread is not SUSPEND
* 800201a6 - thread is not WAIT
* 800201a7 - now dispatch disabled
* 800201a8 - WAIT timeout
* 800201a9 - WAIT canceled
* 800201aa - WAIT status released
* N800201ab - WAIT status released with callback
* 800201ac - thread is terminated
* 800201ad - semaphore counter zero
* 800201ae - semaphore counter overflow
* 800201af - event flag condition not occur
* 800201b0 - this event flag cannot accept waits with multiple threads
* 800201b1 - illegal event flag wait pattern
* 800201b2 - message box have no message
* 800201b3 - message pipe is full
* 800201b4 - message pipe is empty
* 800201b5 - wait object deleted
* 800201b6 - illegal memory block
* 800201b7 - illegal memory size
* 800201b8 - illegal scratchpad address
* 800201b9 - scratch pad in use
* 800201ba - scratchpad not in use
* 800201bb - illegal type
* 800201bc - illegal size
* 800201bd - illegal count
* 800201be - not found vtimer
* 800201bf - illegal vtimer ID
* 800201c0 - illegal KTLS ID
* 800201c1 - KTLS is full
* 800201c2 - KTLS is busy
* 80020258 - invalid such priority
* 80020259 - device name is invalid
* 8002025a - device name is unknown
* 8002025b - pm information is registered already
* 8002025c - pm information is not registered
* 8002025d - major state is invalid value
* 8002025e - request is invalid
* 8002025f - request is unknown
* 80020260 - unit number is invalid
* 80020261 - cannot cancel request
* 80020262 - pm information is invalid
* 80020263 - argument is invalid
* 80020264 - already target epower state
* 80020265 - failed to change system power state
* 80020266 - cannot change device power state
* 80020267 - device does not support such power state
* 800202bc - request to the DMAC failed
* 800202bd - DMA operation is less or equal one
* 800202be - the operation is already queued
* 800202bf - the operation is already finished or not queueud
* 800202c0 - the operation is already in transfer progress
* 800202c1 - the operation is not assigned yet
* 800202c2 - the sync operation timed out
* 800202c3 - dma operation struct is already freed
* 800202c4 - dma operation is used
* 800202c5 - dma operation is empty
* 800202c6 - DMA operation is aborted
* 800202c7 - DMA operation is error
* 800202c8 - physical DMA channel is already reserved
* 800202c9 - physical DMA channel is not managed by dmac manager
* 800202ca - there is a privilege address in link list
* 800202cb - link list buffer is not enough
* 800202cc - the operation is not assigned to physical DMA channel
* 800202cd - the operation is child operation
* 800202ce - it is too much than transferable datasize
* 800202cf - argument is invalid
* 80020320 - Too many open files
* 80020321 - No such device
* 80020322 - Cross-device link
* 80020323 - Bad file descriptor
* 80020324 - Invalid argument
* 80020325 - Unsupported operation
* 80020326 - Alias is already used
* 80020327 - Cannot mount
* 80020328 - Driver deleted
* 80020329 - Async operation is busy
* 8002032a - No async operation
* 8002032b - Device is already registered
* 8002032c - No current working directory
* 8002032d - Filename too long
* 800203e8 - DECI3 No such device or address
* 800203e9 - DECI3 I/O error
* 800203ea - DECI3 Not enough core
* 800203eb - STDIO not opened
* 8002044c - Parameter is not cache aligned
* 8002044d - End of kernel error code Never use this name
== Introduction ==
== Normal errors ==
8002XXXX = Kernel
00000001
Internal Error
80020148
8002013C
80020321
8008273A
Internal Error
80108D50
80410A0B
Hardware Error
WiFi is damaged.
== Errorlist: ==
* 0x0 = no error
* 80020001 - error
