Pandora help please
  • wardogz1919
    • Jul 2010
    Pandora help please
    Well I got my pandora battery today and well my psp is completely bricked so I can make the memory stick without using the adapter and everytime I try to make the memory stick I get this error.
    Not enough reserved sector space
    Now I have no clue if the MMS is fake but I heard that some work
    mine is a 2gb pro duo
  • janobi
    • 1624
    Have you formatted the card correctly? You need to have a small partition on the card. You could also try the new PSPgrader instead, as this can be made on a PC rather than on the PSP. Or if you know someone with CFW, get them to make the card instead.
    If your super stuck mate, then send me your PSP and I will restore it as I have a pandora and working card.
    • jumpinbean
      • Jul 2010
      I am having the same problem and I heard it is a problem with the software that installs the firmware.
      • janobi
        • 1624
        Try PSPgrader 6 instead, you dont need a CFW psp to complete it.
        • kourkoutas
          • Jul 2010
          • 25
          it sounds like there's not enough space on your memory stick. try formatting it and then try again.
          • gazzr72
            • 27
            hi i have working pandora and card im in the manchester area and can meet locally to sort your problem . but there are many ways to solve your problem yourself as mentioned earlier.if you need my help then post here .hope you sort your prob.
            • nukularpower
              Having this same problem. Any help would be great.
              Not enough reserved sector space.
              IPL was not written to MS.
              I've formatted the damn thing 29034 times now. Still says I have no reserved space.
              If I have to partition it, how big of a partition do I need? When I used the tester app it says there is 8 kb available. Do you need more? And how would I make more?
              • JTH
                • 133
                use psp grader 8
                u will get the error when using vista mostly
                if using windows 7 use xp compatible mode for best results
                its a compatabilty problem with ipl injection.
                WE ARE THEPEOPLE
