pandora's battery
  • smirnoff_rules
    • 8603
    pandora's battery
    l have a psp and a m8 at work has just got one and wants me to do it for him , if l do the pandora's battery thing does he need to get a large memory card first or can l flash it using my card ?
    cheers , and have we a tut on how to do it anyway
  • biffo1
    • 420
    smirnoff mate , @ 512 mem card will do for a pandora , and a large card is only needed if he wants to put a few games on well recommeded a 4 gig , best place ive found and ive order 6 free del great service and cheapHere
    [CENTERsigpic[/CENTER]
    • Jaffa
      • 1612
      I assume your psp has custom firmware Smirf.
      Just use disinter in downloads at link below and that will make a pandora and jigstick memory for you. You can just use your memory card as you format it afterwards anyway. You do'nt really need a tutorial for Disinter because once you install it and connect your psp to pc then you just follow the instructions which pop up. Dead easy..the stoogies taught me how to do it.
      • Jaffa
        • 1612
        Found a tut anyway and not at other place.
        Download disinter and the Sony 1.50 3.40 and 3.80 updates
        Start disinter and load each eboot into the correct box and connect the USB and select the PSP's drive letter.
        when you have hit yes to the drive letter start "stage 1" copy the files.
        now it will copy some files over. when it has you will see this
        press ok and close the USB connection.
        goto the game menu on the PSP and select memory stick
        run "pandora installer for 3.xx"
        when you see the menu press R trigger + X
        now you see the warning screen telling you all data will be lost etc
        press L+R+X (L and R are the buttons at the top corners of the PSP)
        this will partition the memory stick and it will tell you to press X to turn off the PSP.
        switch it back on and connect the USB again. disinter will ask you to say yes to the drive letter again.
        after pressing yes start "stage 2" copy the files
        wait for the files to copy and when complete you will see this
        disconnect the USB and goto the game menu and select memory stick again.
        this time run "Despertar del cementrio" and press X to begin the process.
        wait for it to finish, it will take a few minutes, when done it will auto exit back to the game menu.
        select the memory stick again and run the "pandora installer for 3.xx"
        when the menu apears press L+X to copy the "msipl.bin" then it will auto exit again.
        run the "pandora installer for 3.xx" again and press O to convert the battery to pandora then press triangle to exit.
        thats it, to test it take out the battery (and ac adaptor if in) then put the battery back in, all 3 light should flash and after a moment you will be presnted with the pandora menu.
        press X to install 3.80 M33
        To put the battery back to normal
        1: take out the battery
        2: plug the ac adaptor in and turn it on
        3: put the battery back in and run the "pandora installer for 3.xx" and press SQUARE [] to make the battery normal.
        • kryton
          • 51
          LOL
          nice tut. looks familiar
          i wrote it the other day for a guy called dino89 on *COUGH* another forum
          good to see it being recycled
          Kryton <-----AKA Hoagy AKA Larry (or anything JTH wants to call me)
          • Jaffa
            • 1612
            So you are hoagy...well you are a stoogie and I know a stoogies work when I see it just didnt know you were Hoagy....lmao I though hoagy had taken it from one of you lot.
            • smirnoff_rules
              • 8603
              thanx lads will get his psp off him this week and do it cheers
              • kryton
                • 51
                tut tut as if i would steal my own work
                well its their to help anybody that needs help, dont care where its posted.
                the guy i originaly posted it for is a bit slow on the uptake thats why i added graphics
                • kryton
                  • 51
                  forgot to add
                  @ smirnoff
                  disinter only takes up 60.4mb so anything from a 64mb pro duo to 4gb will do the job.
                  • JTH
                    • 133
                    Originally posted by kryton
                    LOL
                    pmsl larry
                    WE ARE THEPEOPLE
                    • Devilfish
                      Administrator
                      • Feb 2008
                      • 7872
                      LOL
                      I knew who you were!
                      Well get them tuts copied and pasted here then so we can all benefit from them.
                      • kryton
                        • 51
                        AHA LOL
                        DF my friend
                        give me MOD status so i can ban JTH
                        • JTH
                          • 133
                          ill gee u a slap never mind mod status
                          WE ARE THEPEOPLE
                          • Devilfish
                            Administrator
                            • Feb 2008
                            • 7872
                            *Kaos chuckles at everyones replies!
                            • JTH
                              • 133
                              u could always buy a datel battery between the 2 of u.and keep for future use.
                              then use this to do card.http://www.digital-kaos.co.uk/forums...?do=file&id=63
                              even easier than disinter.
                              or send me a 512 or 1gb card to put disinter 380 on for u m8
                              WE ARE THEPEOPLE
