Bricked PSP 1000 after flashing Theme
  • fatone
    • Oct 2010
    I flashed a theme to Flash0 and no longer can get to the Recovery Menu in my custom firmware. I don't have a Pandora battery so is there any other way to fix it?
  • deptraisteve
    • Oct 2010
    the pandora batteries are cheap anyhow, get one from dealextreme.com, you will be glad you did, total assurance you wont ever brick it again .
    • janobi
      • 1624
      No, you need a pandora to unbrick the PSP.
      • paul4560
        • Nov 2011
        • 20
        if you know anyone with a psp 1000 like you.they can patch there own sony battery into pandora mode.Then you just would need a magic mem stick(normal card other words) with the files on .
        If not just buy a pandora battery.
        • pspmixer
          • Jun 2009
          • 750
          i bricked my psp like this a while ago now but i used another psps battery made it into a pandora one then fixed it then restore battery back to working order
          i recommend buy a cheap psp off ebay then you can amke the pandora battery from that
          • darcu5
            • Jun 2011
            • 944
            i had a problem flashing mine other day, light came on when i switch it on and that was it, i read about abit and waas going to order a pandora battery for 7 quid from amazon, but then i found a tut, which said to take battery apart and disconnect a pin on the chip, then install pre made 4.01m33 onto meory card , it works fine again now..
