psp 1003
  • headache
    • Feb 2010
    • 26
    psp 1003
    hi all ive aquired psp 1003 i'v got a memory stick also what do i need to do to hack it.its running on 5.00 m33-6
    thanx all
  • JTH
    • 133
    thanx all
    its already done on m33 pal
    format card in psp then put games into ISO folder
    then go to card and play.
    WE ARE THEPEOPLE
    • headache
      • Feb 2010
      • 26
      TRIED THAT, GAME COULD NOT BE STARTED.ITS ALLREADY GOT VIDEO FILE IN ISO FILE,I CAN SEE IT BUT CANT PLAY???.IN PSP FILE A FEW FILES ??1.COMMON
      2.GAME
      3GAMEXX
      4.GAME150
      5.RSSCH
      6.SAVEDATA
      7.SYSTEM
      8.THEME
      AINT GOT A CLUE WHATS THESE??
      ANY IDEAS WHAT SETTINGS FOR THE RECOVERY ARE CHEERS
      • JTH
        • 133
        do search for Prometheus-4 for CFW 5.00 M33
        put into game folder ,run from psp.
        u will get game canot be started for 2 reasons.
        1.u need to update firmware
        2.ur umd is set to normal(umd required in drive)
        press select and change to m33 or sony.
        WE ARE THEPEOPLE
        • dreamsnake
          • May 2011
          • 6
          It probably is due to the configuration.
          1st while in the xmb press select button and you should see a VSH menu. check the 4th entry it should say something like "UMD ISO MODE M33 driver"
          in ur case most probably its something else. if that's the case then do the following steps
          Step 1: shutdown your PSP (either take out ur battery, or press "select" and select shutdown device, or press ur power button for 3 second)
          Step 2: Press and hold R (device is still shutdown)
          Step 3: Start psp with still holding R
          Step 4: you will boot into GEN Recovery Menu
          Step 5: Select Configuration
          Step 6: Select UMD Mode
          Step 7: press x till you get M33 Driver -NO UMD->
          All done
          Hopefully that will resolve ur problem some games work with Sony NP9660 -NO UMD-> option but like 99% works with M33 Driver
          Good Luck
          • Katherine5
            • May 2011
            • 47
            depends on the PSP for mainly:
            5.00m33-6 is said to be best for emulation is best for PSP gaming especially for the latest games
            Good plugins are:
            CW Cheat
            Ultimate VSH Menu
            Game Categories
            Dayviewer
            In the pursuit of something always!
            • pandya
              • May 2011
              • 68
              Just run the D3 updater from game (place it in PSP/GAME) with the OFW file renamed and placed on the root of the MS
              Run Prom the same way
