Black ops first strike pack install
  • m9g
    • 704
    Has anyone downloaded the pack (not from ms) and installed to hdd? if so did it work ok? and how did you transfer from pc to hdd?
    Regards
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
  • djjwdubz
    • 1011
    you need a usb stick, 3gb should do! and it works!
    • m9g
      • 704
      So how do i transfer from the usb stick into the box? and is there any sort of serial or anything?
      a note with the download says i need to install to.....
      HDD:/Partition3/Content/0000000000000000/
      Does the box need to be jtag'd or does it work on flashed box?
      Regards
