Backups Stopped Working !
  • acestu
    • 269
    Hi Fellas,
    My backups of Black ops and Fable 3 have just stopped working
    when i put them in the xbox it just goes to a black screen and everything freezes, its running lt + and they used to work fine, i have even done 2 more backups and they are the same, has anybody else had this problem or could anybody shed some light on this issue....
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • djjwdubz
    • 1011
    run the game through abgx, it will patch it with ap2.5 patch! then it will work!
    • acestu
      • 269
      cheers
      Thanks, i will give it a try, but why have they already been patched abgxed and working then suddenly stopped ......
      cheers
      Acestu
      • janobi
        • 1624
        cheers
        Acestu
        Could be your media. Could be your laser. Could be number of things.
        • djjwdubz
          • 1011
          when the last dash update comeout, the update made them games ap2.5. so if you get a black screen on any of the new games then its ap2.5 to blame.
          • irishbluestaffy
            • 611
            hi i have a flashed box dont no wat sw is on it but it doesnt play new games and b4 that i had to run a disc then put a backup in,now if i patch it with this abgx, will patch it with ap2.5 patch,will it play new games or do i have to get it flashed again,thanx
            • djjwdubz
              • 1011
              if the game is ap2.5 then yes, you will need to update your fw to lt+. if you dont update then the ap2.5 games will not work at all.
              update 1st then use abgx for all the new game!
              theres only about 6 games with ap2.5, if you have kinect you will need to update to lt+, everything will be back to the way it was b4 but, without the boot disk!
              • keefy7
                • 27
                needs to be lt+ 1.1 if u already have that version then update abgx to latest version and run the iso files thru abgx again autofix lvl 3 it will re patch them to ap2.5 the older version of abgx just blanked out ap2.5 once u have done the above burn off as usual and the games should boot as normal
                h***://abgx360.net/
                sigpicNil Satis Nisi Optimum
