You can now convert any off-the-shelf 2.5" SATA Hard Drive and convert it to be 100% XBOX 360 Compatible, saving you a TON of money !
The X360USB PRO HDD HACKER TOOL currently supports the entire range of Western Digital 2.5" SATA Hard Drives, however we will be able to add a range of other manufacturer's and models in future updates.
All you need is the HDSS.BIN file from an original XBOX360 Hard Drive (which can be easily extracted using the X360USB PRO) and use it to convert your WD SATA Drive. The following guide will show you just how easy it is.
Note: The size of the drive is limited to the size of your HDSS.BIN file (e.g. if you have a 250GB HDSS.BIN and you flash it to a 320Gb Hard Drive - then the drive will recognize in the Xbox 360 as a 250GB drive)
To support the the new HDD capabilities of the X360USB PRO, we have begun to manufacture a range of new products to give you a clean and professional Hard Drive update experience.
Full release and credits here: XECUTER X360USB PRO HDD Hacker Tool Released ! - Team Xecuter
