So when is this new dashboard update due? (UK)
  • POOTERMAN
    • Mar 2010
    • 41
    So when is this new dashboard update due to be rolled out to us UK peeps that flashes our firmware back to stock?
    When it does finally hit how long before a new LT firware is released to counter all the new AP protection that featuresin the new update?
    Anyone know?
  • cunny
    • 4915
    Anyone know?
    Short answer? NO
    Only ms will know when the new dash hits uk, and as for firmware, only c4e will know
    • C64
      • 2394
      I've not been following this but the last I heard was it replaced your drive Key with a string of Zeros, meaning that if you do have have a copy of your Drive Key then the machine is a large paper weight.
      I don't know how much truth is in this, probably a load of rubbish, but why let that get in the way of a good story.
      • cunny
        • 4915
        The key location has changed on the newer FW thats why you the 0's. If you have a copy of your key then you should be fine. Jungleflasher will be adjusted acordingly and hopefully current dumping methods wont change to much.
        • janobi
          • 1624
          Hey Witchy!! Not like you to be behind in the scene mate. Earlier versions of JF can still get the key apparently.
          • djjwdubz
            • 1011
            Originally posted by cunny
            Short answer? NO
            cun, only god knows when the world is going to end
            • martiboy
              • 541
              Anyone know?
              There is already new patches out for the main games with ap25 like blackops in abgx
              • janobi
                • 1624
                It aint out yet in the UK. TJ are sitting online awaiting the update. Or a member was at the wkend.
                • xXJediXx
                  • Oct 2010
                  • 214
                  I'm pretty new to all this ..
                  i can just about manage to get my own 'back up's ' on disc myself ..
                  My xbox is one that was flashed about 1 1/2 years ago .. and i use a boot disc for my games even the new ones .. (LOVED LA NOIRE ).
                  Should i take this update, as i have had previous update's and been unaffected .. (though every year when the ban hammer coems down i usually take my console of line for 4-6 weeks)...
                  Was thinking about buying one of the flashing kits myself.. so if i take the update .. can i reflash .. to keep playin
                  or
                  can i take the update and continue as normal with my boot disc ..?
                  or shuold i just stay ofline when for a while .. Wanna be able to play the duke nukem game when it comes out ..
                  Though worst case senario i have a 250gb slim sittin there in its box still
                  • martiboy
                    • 541
                    or
                    When you install the new update the xbox will flash your drive back to original firmware and also change the location of the drive keys. If i was you i would hold of taking the update and waiting for the new firmware that is being talked about (LT+2). Atleast that way you wont need to mess about with boot dics.
                    • xXJediXx
                      • Oct 2010
                      • 214
                      Cheers ,
                      I was under the impressin using the boot disc is better as its less detectable ..
                      AS long as i can play my games its sound i think i will stay off live when the roll out starts ..
                      Just means cant use my sky player ..
                      Though i do have an unflashed 250gb black slim that is in its box :-)
                      And do a bit more reading and see what kit i need to get my box re flashed ..
                      would be cool to do my own instead of forking out for someone else to do it .. :-)
