Liton 7485 - Need Help
  • braindead
    • 103
    AAHHHHHHHH... can anyone help, I updated on Xbox live, and then tried to reflash. However, Jungle flash wont provided me back a valid flash.
    I done the Liton erase, and when it does an intro/device it just comes back with the following info, even though i'm turning it off and on during the second line of dots.
    Sending Lite-On-Erase request to port 0xB400
    Drive returned Status 0x7F
    Device Intro failed!
    If it doesn't provide a valid Staus I cant read the firmware
    Any help appriciated, im nearly there...
  • janobi
    • 1624
    You cant read the fw if its been updated mate. You need an MRA hack to get the key. If you have the dummy.bin then just erase and rewrite.
    • braindead
      • 103
      I know I cant read the Keys, but when I do a device intro it has to provide vaild flash properties before I can erase / right
      • MrFug
        • 880
        Pretty sure the MRA hack has been superceded by the PMT Probe method. Much easier and doesn't require any trace cutting, just a 3.3v switch on your connectivity kit cable.
        Braindead I think I remember having the same issue. I think it's just a case of turning off / on and hitting Intro and the right time. Not 100% sure though.
        • cunny
          • 4915
          Are you using VIA card? I hope you have the correct key? If you've erased the drive (by sounds of it you have) You will need to Send Intro to same port, turn off the drive, wait 3 seconds, power back on. The drive should reappear in flash properties.
          • janobi
            • 1624
            It does indeed, but if the drives been updated then the PMT dont work, and an MRA hack is required.
