!!phat & slim lt+1.9!!
l wouldnt like to to update with a bent box just incase ? its only afew minutes more to be safeany information provided is for educational/experimental purposes only.Comment
No because on the new dashboard the revision for all phat liteons has changed. Hook upto jungleflasher and check revision. Think its 0251. You will want the corresponding fw for that revision if on the new dashboard
Sent from my GT-I9000 using Tapatalksigpic
I am confused! Are you saying that you need to use the fw that says 1.9 (revision 0251) or the one that says 1.1?
I ask because if u let JF 1.84 autoload the target fw it will load 1.1 - if you want to use the fw labelled 1.9 then u have to load it manually.
Another problem - i have flashed my lite on using 1.9 but it will not play ap25 games (Black ops or nfs hot persuit), it says 'play game' but then boots to a black screen. It plays non ap25 games ok. I tried flashing with the autoloaded (1.1) fw but it does that same.
I am really confused now! given that the drive is a lite on 7450c what fw file should i be using? And has anyone any idea why it will no longer play ap25 games??
ThanksComment
I have just read on another forum that this version of the fw does not support ap25. Important info to know if you are an avid Black Ops fan - as this game will not load once you have updated to 1.9
I would still like confirmation that the correct .bin file to use for a lite on 7450c is LTPlus-025v1.9 - not 1.1 as autoloaded by JF.
ThanksComment
The correct file is the LT+ - 025v1.9.I have just read on another forum that this version of the fw does not support ap25. Important info to know if you are an avid Black Ops fan - as this game will not load once you have updated to 1.9
Did you rerun your iso through abgx? Did you repatch the games with the new ap2.5 checks?
You have to repatch the iso with the new info, or the game wont boot. You cannot use your old burn, as it wont work.
ThanksThe problem here is the latest dashboard flashes a liteon to 0251. So then you will need the 1.9 FW. The DAE table was changed in this update, thus, repatch and reburn of AP25 games (as Jan Said)I have just read on another forum that this version of the fw does not support ap25. Important info to know if you are an avid Black Ops fan - as this game will not load once you have updated to 1.9
So if your dash version is pre 13141 then use 1.1 for corresponding revision of your drive (7 8 9 series ect)
If your dash is POST 13141 the use the LTPlus-025v1.9.bin for all PHAT LITEAON that HAVE BEEN FLASHED BY THE LATEST DASHBOARDLast edited by cunny; 18 June, 2011, 19:02.sigpic
Any reason why i cant get 1.84 to run? I get error
"THE PROGRAM CAN'T START BECAUSE LIBUSB0.DLL IS MISSING FROM YOUR COMPUTER. TRY REINSTALLING THE PROGRAM TO FIX THIS PROBLEM"
libusb0.dll is in a folder in with JF, I can run other versions no probs.
I also noticed that in the 1.84 folder the portio files aren't there like they are in other versions. is this correct?
DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
