xbox update problem plzzzzz help
  • leeunwin
    • 269
    heyup people what it is my 360 is flashed been working fine isnt banned from live are anything like that the problem is now when i try and play a game on live it says i have to update 1st when i click update it restarts to do update then fails and i end up with 1 red light so problem im having is i cant play any game on xbox live as it requries me to do a update
    anyway of stopping it asking for a update
  • cgscott
    • 3513
    What drive is in it? My samsung threw up and error when i tried to update it. Had to return to stock then update.
    Seems a bit strange it wont take update.
    You got the latest dash?
    Patience is a virtue.
    • janobi
      • 1624
      Is your drive spoofed?
      • leeunwin
        • 269
        heyup thanks for replys
        ive tried update via internet and using usb stick still throws up the 1 red light error e66
        im not sure what drive it is i think its a benq and no it isnt a spoofed drive mate?
        i no from what ive read is that i need to apply the update then reflash problem is cant apply update
        • cgscott
          • 3513
          Might work if you return drive to stock then update then flash CFW again.
          E66: DVD Drive Error - Dvd drive pairing failure: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer. if drive can eject, read, and write under windows but errors on console, replacing original firmware should fix issue.
          • leeunwin
            • 269
            i havent got the original stock firmware are keys
            • leeunwin
              • 269
              if i was to buy another 360 that hasnt been flashed!!
              then upadte to latest dash if it hasnt already then flash it would that be ok?
              • cgscott
                • 3513
                Even better it never took the update. You can pull the key from the drive then flash to stock then back to CFW after update.
                The new LT 1.9 comes with OFW orignal firware for the benq. Just flash that then update.
                • leeunwin
                  • 269
                  hiya so i need to read the key then save it to computer?
                  then how do i go about reflashing to stock firmware do i need to download the stock firmware for my drive and use that to reflash the drive? if so where would i get stock firmare?
                  ps thanks for info
                  • cgscott
                    • 3513
                    Heres the firmware
                    http://hotfile.com/dl/120935934/28dc115/Latest_iXtreme_and_Stock_Firmware_Pack.rar.html
                    Yes take the firmware from your box which has your key. Save it.
                    Then unrar that pack. Search for OFW for benq.
                    Use JF to add OFW. Spoof your key over.
                    Flash. Relace back in console take the update. Then repeat the process but with 1.9lt for your benq.
                    • leeunwin
                      • 269
                      dont suppose you could give me stock for samsung drive i thought it was benq mate sorrrrry
                      • cgscott
                        • 3513
                        All are in that pack.
                        Thats the reason its not updating my samsung done the exact same thing.
