Ok im haveing a few issues trying to flash this drive. It has the the xbl update. Im using a via ck3 with a prob 2. from what i have seen the only way to flash the drive with the probe 2 is the mra witch i have done. I got the key a backed it up. Then fixed all the mra cuts. Put the drive back together and flashed with lt 1.9 or so i thought. Put an original game in and played fine. Put a backup game in and get the discs unreadible so tried others and got the same. Hooked the drive back up to the pc and got all the dive propertes clicked lition erase and now my pc cant find the drive. All i get is no drive detected. Is there anyway to fix this or is it cream crackerd thanks
74850c drive not detected
Thanks cunny. The drive is going again. But still cant get any backup game to load. What im doing is Loading the original firmware to the source LT 1.9 to taget. click liton erase twice on of on with the ck3. Then click write. Once thats done i click ouro and try the drive in the xbox but still no back ups work. Here is my jf log
JungleFlasher 0.1.84 Beta (250)
Session Started Mon Jul 18 21:16:04 2011
This is a 32 bit process running on 2 x 32 bit CPUs
portio32.sys Driver Installed
portio32.sys Driver Started, thanks Schtrom !
Found 4 I/O Ports.
Found 2 Com Ports.
Found 8 windows drives A: C: D: E: F: G: I: L:
Found 3 CD/DVD drives E: F: I:
Loading firmware file C:\Users\martin\Desktop\dylan xbox keys\Lite-OFW.bin
MD5 hash: 819007319d4f7db0273f4596b12be059
Drive key @ n/a
Firmware Osig: [PLDS DG-16D2S 0251]
Firmware is: Stock
Auto-Loading firmware file G:\firefox downloads\JungleFlasher.0.1.84.Beta(250)\JungleFla sher v0.1.84 Beta (250)\firmware\LTPlus-025v1.9.bin
MD5 hash: 71cfb6569fd42a1d4eb243dbd4d3b159
Genuine LT plus v1.9
Drive key @ n/a FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Firmware is: LT-Plus 1.9
Spoofing Target
DVD Key copied to target
Target is LT - ID strings not copied to Target
Serial data already matches
Target rev is LT 02510C, serial info not copied
Sending Lite-On-Erase request to port 0xD000
Drive returned Status 0x0
Serial flash found with Status 0x72
Manufacturer ID: 0xC2
Device ID: 0x11
Flash Name: MXIC(MX25L2005)
Flash Size: 262144 bytes
Getting Status from port 0xD000
SPi flash found with Status 0x72
Sending Chip Erase to Port 0xD000
Erasing:
Writing target buffer to flash
Writing Bank 0: ................
Writing Bank 1: ................
Writing Bank 2: ................
Writing Bank 3: ................
Flash Verification Test !
Reading Bank 0: ................
Reading Bank 1: ................
Reading Bank 2: ................
Reading Bank 3: ................
Write verified OK !
Sending Vendor Outro to port 0xD000
Drive is Lite-On..
Key found in KeyDB at record (4 - dylan xbox keys)
Key is:
Key has been tested and verified, thanks C4eva !
I have removed the drive keys from this postComment
It is sounding like a laser issue so a pot tweak could help. But it could be just time for a new laser/drive. Did you disconnect the laser ribbon prior flashes? This has been known to cause laser issues.
Hope your sorted soon.
You be amazed how easy the pmt method is to retrieve keys from liteons now. Takes less than a minute.
Sent from my GT-I9000 using Tapatalksigpic
All sorted now. Gave it a pot tweek and all good now. Dont know why i just didnt try that to start with. Ive been at this box for nearly 5 hours now and it was almost throwen out the window. Sorry for wasteing your time cunny and thanks for all your helpIt is sounding like a laser issue so a pot tweak could help. But it could be just time for a new laser/drive. Did you disconnect the laser ribbon prior flashes? This has been known to cause laser issues.
Sent from my GT-I9000 using TapatalkComment
