please note not my work just thought it might help a few people.News:
Last updated: August 5th 2011
AP checks are now at version 2.6 with the July 19th 2011 update.
LT+1.91 has been released with a new JF that overcomes the new AP2.6 checks.
You do NOT need to re-burn your AP2.5 discs if they were patched by abgx after the May 2011 Update (13146).
Firmware Download Links:
(Link broken? Please, send me a PM and I will fix it)
LT+1.91 (Phat and Slim, Stock Firmware included):
Download Latest_iXtreme_and_Stock_Firmware_Pack.rar for free on Filesonic.com
JungleFlasher Download Links:
Newest JungleFlasher 1.86 beta (267):
Download JungleFlasher.0.1.86.Beta(267).rar for free on Filesonic.com
JungleFlasher 1.85 beta (257):
Download JungleFlasher.0.1.85.Beta(257).rar for free on Filesonic.com
JungleFlasher 1.84 beta (250):
Download JungleFlasher_v0.1.84_Beta_(250).rar for free on Filesonic.com
Newest JungleFlasher Tut 1.4.3 PDF:
-included in the Documentation folder inside JungleFlasher 1.86.rar
Download jftut1.4.3.pdf for free on Filesonic.com
System (Dashboard) Updates:
Install via USB:
July 19th 2011 Update (2.0.13599): Download SystemUpdate_13599_USB.zip for free on Filesonic.com
May 2011 Update (2.0.13146): Download SystemUpdate_13146_USB.zip for free on Filesonic.com
Install via CD:
July 19th 2011 Update (2.0.13599): Download SystemUpdate_13599_CD.zip for free on Filesonic.com
May 2011 Update (2.0.13146): Download for free on Filesonic.com
Thanks to c4eva and crew, TX, TJ, and everyone else who worked hard to please the public and release this ASAP.
BIG thanks to snurf, tysonic, Hancock13 for helping keep this thread under control by answering questions!
FAQ
FAQ directly from #c4e IRC
? It is recommended to run updates without spoofed drives, and latest fw.
? The new 13599 dash updates AP2.5 challenges and lock the 9504/0272 spi! And reflashes the drive. If you want live, update. If you can?t live without games, stay offline or else buy a replacement pcb.
? If loading pre-13146 fw on source JungleFlasher will autoload 1.1. This is completely normal. If you want to use your old files ensure that xbox is updated first, then manual load the 1.9 fw and press spoof source to target
? When spoofing from old fw to new one it IS normal to say serial info not copied and ID strings not copied to target.
? For the ones that want to flash their 74850C liteon drives to stock use the 1a000 file. Don?t ask why, just do it.
? For everyone getting stuck at erasing/writing phat drives, use 1.84 version.
? If when loading the LT+ 1.9 says stock, you are using old version of JungleFlasher, please download and use the latest one.
? IMPORTANT! For those who want to flash a 0272 drive, please rename the 0272-OFW.bin to LTPlus-0272.bin and put it in the firmware folder along with the LTPlus-0272-v1.9.bin
? Determine what fw to use using the drive properties on JungleFlasher.
? ALL updated phat lite-on drives can only be dumped with MRA or PhatKey method. Any other drive can be dumped exactly as before.
? LT+ 1.1 on all drives except hitachi are not Xbox live safe on 13146 update so we recommend DO NOT flash back to LT+ 1.1. Instead use the new LT+ 1.9 fw
? The 13146 update, writes stock fw on all drives except hitachi, all phat lite-on drives now become 02510C, 9504 become 0272, all benq drives become 04421C and Samsung are just patched.
? 13146 update can?t retrieve your key if you don?t have it on drive.
? You need to wait for a new jungleflasher version to use with the pcb.
? Because Microsoft has enabled the write protect on 9504 drives ,which now are 0272, whenever they want , it is recommended to use the kits as you can control if they are write protected or not.
? Because compatible motherboards for 0225 and 0401 are hard to find as they are very rare and these drives are very picky, it is recommended to get an x360usb as it is confirmed to be working 100% with these drives.
What is 1.9? Where is 2.0?
LT+1.9 is designed around the May 2011 dash update (13146). It is considered LIVE safe (never 100% safe).
LT+1.91 overcomes the new AP2.6 checks that came with the July 19th 2011 dash update. AP2.5 discs patched after the 13146 update do not need to be re-burned.
LT+2.0 will come out later in the year. 2.0 will allow support for burnt XGD3 discs. There are currently no games that use the XGD3 format so this is not yet needed.
Do I need to re-burn my discs?
You only need to re-burn AP2.5 games if you haven't already patched them after the 13146 dash update. You will need LT+1.91 if you have the July 19th update.
AP2.5 games: Assassin's Creed: Brotherhood, Fable III, Need for Speed: Hot Pursuit, Halo Reach, Call of Duty: Modern Warfare 2, Call of Duty: Black Ops
First run them through abgx to be patched and then re-burn them!
How should I flash this firmware if I have a phat drive with LT+1.1?
If not updated to at least 13146 dash, start at 1). If updated to at least 13146 dash, start at 3).
1) Flash to stock firmware
2) Update dash to 13146 via USB or CD (see above for download links)
3) Use Dummy.bin as source
4) Use LT+1.9 as target
5) Click spoof source to target (notice key is copied to target)
6) Flash!
7) Proceed with July 19th 2011 System Update (2.0.13599)
Do I have to extract my key again?
As long as you have your old key, you do not have to extract it again. Be sure to use the latest JungleFlasher.
My target key shows FFFFFFFFFFFFFFFFFFF. What do I do?
With your dummy.bin loaded into source, click spoof source to target.
What do the folders (drive)_Post/Pre_13141 mean?
Post_13141: new firmware (1.9) after the 13146 dash update
Pre_13141: firmware (1.1) before the 13146 dash update
Why is there only one LiteOn Firmware (phat)?
After the latest dash update, all phat LiteOn drives now have the FW Ver. 02510c. Because of this change, only one firmware is needed.
My JungleFlasher fails to open. It says it is missing libusb0.dll. What do I do?
1) Open root JF folder called "JungleFlasher v0.1.85 Beta (257)"
2) Open folder called "libusb"
3) Copy libusb0.dll
4) Paste libusb0.dll in root folder "JungleFlasher v0.1.85 Beta (257)"
-if yours was deleted, here is libusb0.dll: Download libusb0.dll for free on Filesonic.com
Which orig-74580c FW do I use? 1a000,1b000,1c000,1e000?
note: this method can also be used for BenQ
1) Load your dummy.bin into source
2) Check what it says at DVD Key @
3) Use the corresponding orig-74580c FW.
Install via USB:
Install via CD:
FAQ
6) Flash!
3) Copy libusb0.dll
