my son has just got 360 4 xmas wants 2 go live how do i do this. modem has 1 ethernet port which is used for my pc and he has an ethernet cable for the 360. i would be greatful 4 any help as he thinks i am clever ha ha thank you
360p
If you are using the wireless side of the router then it needs some simple configuration to setup encryption etc, but if you are going to connect via a LAN cable then it's very simple.
Basically what you'll do is...
1. Plug your modem in to the router using the existing cable.
2. Get another network cable and insert one end into the router and the other end into the PC - this will allow your PC to access the Internet via the router.
3. Get another cable and plug one end into the router and the other end into the Xbox360 Let the Xbox detect the settings itself - this will allow the Xbox access to the Internet.
You will not need to reconfigure anything, both the PC and the Xbox will use DHCP on the router to acquire a local IP address and the router will then route all traffic for you automatically.
(Some routers needs some slight configuration, such as you manually having to enable the DHCP server, but the majority of routers come with DHCP enabled)
So your shopping list so far is ...
1 router
1 cableLast edited by C64; 30 December, 2008, 23:06.Comment
