Flashing Liteon back to stock without original dummy file
  • fermec
    • 26
    Hi There
    I would like to flash my liteon 74850c drive back to stock so I can load the latest dash update then flash to v1.9, the box is already banned so dont have to worry about it being flagged.
    The problem is I dont have the original dummy file so is there any way I can flash back to stock without the original dummy file.
    Is it possible to just update to the new dash update useing usb without flashing back to stock, I have heard if I do this it can get caught in a loop, so dont really want to do this.
    Any help would be great.
    Cheers
    Fermec
  • cunny
    • 4915
    Depends on what firmware is on the drive. If its LT then your gonna have to get someone to dump it for you by MRA or PMT (probe v3)
    If its ix 1.5 ect you can dump it via tray half open and dummy from ixtreme in JF.
    You can post the drive to someone who will dump the key from it for you, usually you would have to cover the postage.
    • fermec
      • 26
      Ok I have the drive details I just dont have the original dummy file when it was stock I do have the Lite_CFW and key from when it was last flashed but that is from ix firmware not stock so is it possible to flash this back to stock useing this?
      • cunny
        • 4915
        Yes if its the right 1 for the xbox then just use it as yiur source an spoof it over
        • fermec
          • 26
          Thanks for that cunny big help
          btw great game on sunday
          • cunny
            • 4915
            I sent you a PM offering to dump the key for you. Let me kno either way if you would like me to do it for you.
            • fermec
              • 26
              Thanks for the offer but I should be fine now.
              Thanks for your help
              • fermec
                • 26
                I have done the dashboard update useing usb then flashed the drive useing LTPlus-025v1.91 but it will not see bodycount, it does however play backups as I have tried my backup of deadspace 2 and that works fine so Im puzzeled.
