Just fort i would let everyone know that dead island has also been released on the old disc format and as we speak is doing the rounds on most good and some bad torrent sites....Back of the net!
DEAD ISLAND IS PLAYABLE ON NON JTAG XBOXES ...YES
Tags: None
I went to put on this game and it asked to update ..
Half way through updating it, comes up that it can't read the update from the disc and seems to be in some loop ...
(pressed green when i shoulda pressed red)
When I start the Xbox, it comes straight up on that screen again ..and not the dash board .. Am I ~~~~ed....?
Any ideas ..?
So basically I think I've bricked my box on this ..Comment
I've heard it reflashes your console back to stock half way through the update. Reflash your 360 drive to lt 1.91 then put your dead rising disc back in and it should update.I went to put on this game and it asked to update ..
Any ideas ..?
Until you reflash your drive it will loop I thinkComment
sorry cunny i spotted ur post just after putting mine up m8 , i was excited like many others about the game and rushed 2 post to let others know with out reading my other thread , i am a dingbat !Comment
If its a later dash than 2.0.13146.0 then it willl for the XDG3 support. Unsure if reflashing of the drive works. Heard multiple fixes or suggestions but as i always return to stock and take update over net then wont affect me.
Try from orig disc, if no, maybe usb
Then try the abovesigpic
When I boot the Xbox up ..
I just get a status code and it's asking me to insert the disc for update ...
Let it unplugged overnight ..
Justvpowered it up and it straight to the black update screen ...
Think my mate has the gear I need to reflash it ...
I HOPE ..
Do I reflash drive with JF and take live update then reflash .?Comment
All drive flashes can be done via jungleflasher. However you still might need the original copy of the game it failed on. I'd try to rent it out. If the update has flashed the drive then you will need to reflash it back to a CFWsigpic
Might be a problem as the pirated version is on xdg2 disc, whereas the uk version is on an xdg3 disc. Probably easier to install the update off a USB or something.
Thats if it will allow it. Depends on where its gotten stuck. Was reading on TX Forums with users with same issue, was recomended that the update was taken from the original game as they could not use usb.
This is the thread
Code:http://team-xecuter.com/forums/showthread.php?t=69886&highlight=update+loop
Troubleshoot Xbox 360 Update Problems | Xbox Error Messages - Xbox.com
Also is it a spoofed drive in the questionable xbox?Last edited by cunny; 9 September, 2011, 12:52.sigpic
