PAL 50 PAL 60 query
  • dassey
    • 15
    PAL 50 PAL 60 query
    Hi guys, hope this is a simple one for you, cos its not for me. Got a bog standard TV with Xbox 360 attached. Plays most games ok. Recently bought smackdown v raw and a message came up telling me to change to Pal 60. Managed to eventually do this (from Pal 50) but the game only plays in black and white. What do I need to do. Help and advice greatfully appreciated..Dassey
  • Studulike
    • 33
    Your TV does not support 60hz fully m8 so it displays in B/W.
    Only answer get a new TV.
    Sorry best I can do for you.
    • Studulike
      • 33
      One other thing to check, see if the TV is set to RGB input as this may solve your problem.
      • apc
        • 7
        Got another pal 50 to 60 question if anyone can help
        Can you change from pal 50 to pal 60 if the 360 is linked to a monitor via vga?
        Just tried a old game and it says the game only works on pal 60
        • mortmaru
          • 39
          Monitors work different what model is the monitor and have you checked your settings on 360 so its already set to pal60
          • apc
            • 7
            Monitor is a NEC 20WGX2
            I have two 360s 1 is set to run at 60 one is not
            Looks like the 360 does not give the option to change if only a vga is connected. Will have to dig out the old lead for the tv just to change the settings.
            • mortmaru
              • 39
              That monitor will work fine use the dvi connection if you have a 360 with hdmi.
              • janobi
                • 1624
                If its showing in black and white on 60hz it means your tv does not support NTSC output.
