you will have to reflash it regardless as the 1st update will flash your drive back to stock
update fail on gof3
think l will cut a hole out of my xbox its been apart 10 times this year
and l bet there will be another update every month till xmas
any information provided is for educational/experimental purposes only.Comment
i tried both updates in order and niether worked,any help please just getting :This is due to your xbox not being LT1.91 firmware and not running the latest dashbord,
One of a few fixes are as follows
download the 13146 dash board from here Xbox 360 Dashboard Update 2.0.13146.0 Download [Final Version with Avatars]
unzip it and put the folder on to a usb stick then place the usb in you xbox and turn it on this should update fix the update loop,
now you want to install the latest dash 13599 do the same again but using this update instead
once all this is done you will then need to reflash your drive to 1.91 Lt as it would have been flash back into its original state
but your xbox will need to be reflashed if you want to play backup games
cant update your console.please visit xbox.com
status code: 3080-335a-b800-0402-c000-016b
help please thanks mickyComment
fixed it by doing this
xxxx-xxxx-xxxx-xxxx-C000-016B
xxxx-xxxx-xxxx-xxxx-C005-3002
Your console had a problem during the update process. Carefully, follow these step-by-step instructions:
1.Eject the disc tray and remove any disc from the console.
Important Do not close the disc tray. Leave it open.
2.With the disc tray open, remove the power cord from the back of the console.
3.Gently push the disc tray about half-way back into the console.
4.Plug the power cord back into the console.
5.Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
Important Do not use the controller button or the disc tray eject button to turn on the console for this step.
6.Try updating your console software againComment
but now no backup games
((( anyone near burnley,lancashire flash with new 3.0 lt fw? cheers micky
