BAD FLASH NEED ADVICE
  • paulwv9
    • 20
    flashed my first 360 about 6 months ago, totally f****d it up, never backed up key and lost the lot after dumping firmware.
    was told at the time there was no way of retrieving the key as software for geting info from mb didn't excist.
    is that still the case ? don't want to hang on to box for ever.
    have successfuly flashed about 8 boxes since then, think i was trying to run before i could walk on the first one !
    any help is much appreciated
    cheers
  • dowlinr
    • 226
    not sure about software existing to extract the key. I'd sell it in bits, at least that way you'd get some cash for it.
    • cunny
      • 4915
      whats the system info/drive info mboard info.
      Do you have the bad flash data?
      • C64
        • 2394
        cheers
        If the drive controller is still working then your key will be safe.
        • gazza666
          cheers
          If you have lost the lot just dump the firmware again
          the key will be ok
          • mortmaru
            • 39
            What model drive is it?
            • mp3boy
              If you have written to the drive without taking a backup first, there's no way to get the key.
              If it hasn't been written over but the drive is just broken, you can get someone with the right skills to desolder the firmware flash chip and read it on an external programmer.
              There is still no way to recover a key from a 360 without a working, matched drive. You need to boot into linux to get the key from the motherboard, which needs a game exploit, which needs it able to play games.
              • Oggy
                • 29
                They let any riff raff in here
                • wozzo
                  • 198
                  Sketch its the xbox sceners
                  • Oggy
                    • 29
                    Nah, me and mp3boy have more in relation than XBS
                    • cunny
                      • 4915
                      at all did you save the key to the hdd of the pc?
                      Then maybe a data recovery program?
