Burning XGD3 Info With ImgBurn
1. Go to Write tab and ensure Layer Break is set to Calculate Optimal
2. So on the startup screen again, press Write image file to disc
3. Choose your .dvd file in source and press Write (x2.4)
4. You?ll get a message saying there isn?t enough space, don?t mind
that and say Yes
5. Also you?ll get another message that Layer Break exceeds L0
capacity. Say Yes
6. Now you?ll get an error, ignore that and just press Continue and
let the writing process start
7. After some time you?ll see that the layer changed at 2,086,912.
That?s normal
8. At 97% you?ll get an error, ignore it as well by pressing Cancel
9. After the error you immediately get a message to close the disc,
says Yes to that, let it finalize the disc.
Not my work but thought it may be helpfull
that and say Yes
capacity. Say Yes
That?s normal
