hey peeps, xbox 360 hard drive help pls...
  • saj1985
    • 785
    hey peeps, i got a phat xbox 360 with a 250gb hard drive,
    i want to know how to format the xbox hard drive to use as a normal hard drive for pc etc, been searching but cant find a tutorial,
    can anyone help please?
    i dont use much memory on the 250gb hard drive,
    i've ordered a dreambox800se i thought i could put that 250gb in the sat box and just buy a 20gb hard drive for the xbox 360 cheap on ebay
    thanks!
    Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
  • martiboy
    • 541
    Your Xbox hard drive is just a sata hard drive open case plug into your pc go to my computer then right click format job done. You would prob be better and cheaper buying a normal internal hard drive from eBay and keep the Xbox hard drive as it is. The Xbox hard drive is worth more.
    • saj1985
      • 785
      so after formatting the 250gb drive i can put that in the sat box right?
      the 250gb 2.5 hard drives on ebay are about ?25,
      the 20gb xbox 360 hard drives are about ?10 on ebay.
      cause i dont use much memory on the 250gb xbox 360 hard drive,
      i thought i could use that on sat box and just get a cheap 20gb xbox 360 hard drive for the xbox 360.
      if i get a cheap 20gb xbox hard drive,
      is it just a matter of connecting it on to the xbox and thats it, its ready to use?
