help please
Mate you still need your burner. Update your Xbox to the latest dash. This update will flash your drive to the new stock firmware which will be 02510. Once you have your srive to the new stock just use jungle flasher and follow what it say. I am also assumming you have the correct tools and kit to do the job.Oh right, dvd writer arrived today, blimey that was quick only ordered it saturday evening. Surely you cant burn games to a single layer dvd?
I'm not sure which lt f/w to use for my DG16D2S, I have d/l the cfw pack which has loads in it but none of them mention my drive in the title
Sent from my iPhone using TapatalkComment
Yes mate, i thought comment was a bit strange, drive is in and flashed, I have flashed a few drives before, have the ck3pro, problem I have is I dont know what cfw to use in the pack i have from xbins .....Mate you still need your burner. Update your Xbox to the latest dash. This update will flash your drive to the new stock firmware which will be 02510. Once you have your srive to the new stock just use jungle flasher and follow what it say. I am also assumming you have the correct tools and kit to do the job.
LTPLUS-0225-v2.0
LTPLUS-0225-v2.0u
LTPLUS-025-v2.0
LTPLUS-0272-v2.0
LTPLUS-0401-v2.0
LTPLUS-1071-v2.0
LT-liteon-0800-v3
Cheers
DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
There he is
cheers
hehehe right now second problem, upgraded my pc and m/board doesnt have pci slot for the via card
have plugged sata from the board into liteon drive and jf not seeing it, says no via drives - any ideas what i can do now apart from get my old pc back?
Heres the spec of the mb
Chipset Intel H61 Chipset Motherboard
Audio 5.1 channel HDA
Form Factor uATX form factor 9.6 inch x 7.8 inch
IO 1x PS2 KB/MS port.
1x DVI-D port
1x VGA port
1x Serial port
1x RJ45 Lan port
1x audio jack supports 3 jacks.
6x USB 2.0 ports.
LAN Gigabit Lan
Socket Type 1155
USB 6
Max FSB Dual channel DDR3 1333/1066
Max Memory Capacity 8GB
Memory Slots 2
PCI 0
PCI-EX 1 x PCIe2.0 x16
2 x PCIe x1
SATA Ports 4Last edited by m9g; 24 October, 2011, 19:58.
Thats a bit of a bummer mate. Do you have any mates that would let you use there comp till you flash the drive.Comment
no - ah if i choose "include non-ide drives" then it appears, is this good enough?
Also do i need to re-probe it as i already have the key from flashing it last year? if i do then what method with the ck3probe v2 - the old r707 way or this phatkey button method -
Switch 3.3v inline switch OFF
Probe the point MPX01
Inline switch off? where that?
Cunny - stuck all cfw in firmware folder and when i choose open fw and direct to that folder it wants to default load one called ix16 which isnt there anyway so do need to know which one i use
RegardsLast edited by m9g; 24 October, 2011, 21:17.
If u have the correct dummy.bin then no and are you using the current version version of jungleflasher.
A prove v3 or a.convertor cable (tut posted of making ur own) will dump any phat liteonsigpic
Ummm dummy.bin I have was created along with the key over a year ago when i originally flashed it, now that it is back to stock and have done an ms update will I need to create dummy again?
So my ck3 probe 2 isnt any good then?
JF i'm using is 1.89
Regards
You can use the probe 2 with mra if u wanted but that dummy file will just need spoofing into lt2.0 for 0251 fw. Jf wont auto load it due to revisions are differant.
If ur unsure which to use. Load your dummy.bin into source. Then stock 0251 into target. Spoof it. Save it. Load it again into source and let jf auto load 2.0.
I'm not sure what's the latest version as 1 been released while I not been on so just goto jungleflasher.netsigpic
My understanding of the new burner drive max is that it will allow you to burn an xdg3game .iso to a single layer disc, at least that is what I have read. As for burning xdg3 discs using an existing burner I have burned a number of them using Clone CD and they all work fine - no new burner required.Oh right, dvd writer arrived today, blimey that was quick only ordered it saturday evening. Surely you cant burn games to a single layer dvd?
I'm not sure which lt f/w to use for my DG16D2S, I have d/l the cfw pack which has loads in it but none of them mention my drive in the titleComment
Ah lovely thanks for confirming that i thought it was that one.
Cheers
last night i loaded the LTPLUS-025.bin into the source, spoofed my key into it that I had when i originally flashed it over a year ago and created a CFW and saved it.
Now all i need to do is get the drive into vendor mode and erase and write the CFW
Am I right?
tried getting into vendor mode last night but drive just had 0x51 error
Regards
Xgd3 get burnt to duel layer discs. No burner in the world will allow you to fit it onto a single layer disc. When using clone cd you do know that you are missing 3% of the gameMy understanding of the new burner drive max is that it will allow you to burn an xdg3game .iso to a single layer disc, at least that is what I have read. As for burning xdg3 discs using an existing burner I have burned a number of them using Clone CD and they all work fine - no new burner required.
