problems with xbox 360 drive
  • tamgunner
    • 691
    hi all got a small problem with ma xbox drive when i press the eject button it doesnt eject it makes a small noise. when i manually eject the drive the power the xbox up it shuts as normal the laser lights up once then thats it.
    any ideas?
  • cunny
    • 4915
    Manually eject? Press eject on the console?
    • tamgunner
      • 691
      i do cunny but thats the problem it doesnt open!
      • daz24c
        • 380
        have you tried ejecting it from the xbox menu? what happens then?
        Thank Me If I Help You
        • tamgunner
          • 691
          no havent tried that yet ill give it a go i think it will be the same tho
          • cunny
            • 4915
            You need to do that, sounds like the drive band could be worn
            • tamgunner
              • 691
              tried it just the same. ive ordered a new laser cause it was on its last legs anyway
              • micflair
                • 275
                Its not the laser mate.
                When you press eject give your 360 a little tap on the top of the drive and it will open.. you need your drive replacing kid.
                • tamgunner
                  • 691
                  i have everything in bits it was workin fine till the laser started playing up!
                  • micflair
                    • 275
                    Ok try this, on the drive opening mechanism there is a small rubber band, prob 1cm or so in diameter. Take it off, and put it in a cup of hot water for 5 mins, it will tighten it up a bit. Take it out, dry it off and then fit it back on and put it all back together.. will work for a bit longer
                    • mr.mojorisin
                      • 247
                      i agree with micflair ^^^^^^
                      mine used to be temperamental on opening until i took the drive apart and cleaned the rubber band and drive cogs with a cotton bud
                      • micflair
                        • 275
                        Yeah it can help it out last a bit longer, obviously replacing the band is a better idea. Id rather just replace the drive to be honest. But if its an old drive that causes another problem of being able to find a `new' old drive.. now that spoofing is kinda out the question..
                        • tamgunner
                          • 691
                          ill give it a try ta
                          • tamgunner
                            • 691
                            u can still get the drive on ebay for about ?15 ?20 but for that i could be another faulty xbox with rrod fix it. ive got another drive here but i would need to change the keys over
                            • cunny
                              • 4915
                              You can buy refurbed drives from a few places. Think I paid 20 for 1. But the drive bands are a few pence so I'd replace that first off.
