how to remove unsupported disc error
  • titchmc
    • 61
    this is from another forum but it works
    1. Disconnect from internet.
    2. Go to settings and then memory.
    3. On the xbox 360 control type (LB,RB,X,LB,RB,X)
    4. If that does not work try (RB,LB,X,RB,LB,X)
    5. It will deleted the update (system will reboot).
    6. Go back to setting and clear the cache on every hard drive that u have restart the console and that should do it.
    If your on the beta dash go to settings, system then storage and enter LB,RB,X,LB,RB,X. That's what I did on my Liteon phat console.
    But note if you go back online it will ask you to update again. Hay but at least you can play your games again.
    SAINTS ROW 3, NFS RUN AND MW3 WORKS AGAIN!!
    Others here can also confirm it worked for them too. But maybe it doesn't work for all.
