Benq drive wont stay closed
  • tkm18
    • Aug 2009
    • 158
    Have a benq drive that the tray was jamming, opened it up, cleaned it up, now it the tray wont stay closed.
    Green light remains flashing meanin the is open, press eject button to close, second or so later, the drive pops back open.
    Was flashed month or so back and untouched since then, so shouldnt be firmware related.
    Any ideas?
    TIA.
  • Fellianis Wig
    • 427
    benq drive that won't stay closed
    • tkm18
      • Aug 2009
      • 158
      Originally posted by Fellianis Wig
      Thanks, read that earlier and it was kinda confusing, the op said he replaced the power cable and it made no difference, then other posts towards the end suggest it's the power cable.
      Will give that a blast later.
      • tkm18
        • Aug 2009
        • 158
        Right, this is deffo a motherboard issue.
        Changed the power cables, no difference.
        Hooked up my ck3i, powered it via that, not reading disks but. Gonna adjust the pot and see if that helps read the disk.
        As for how I'm gonna get the drive ejecting properly who knows. Lol
        • cunny
          • 4915
          Does the drive close all the way? Sounds to me as tho its either not closing fully
          • martiboy
            • 541
            when you had it plugged into your ck3i did you try opening and closing with that.
            • tkm18
              • Aug 2009
              • 158
              Deffo closing fully, like i say, fine when its hooked upto the ck3i, apart from not reading the disk, which will be a seperate issue.
              Reading up trying a different drive wont work either, its been tried.
              Heres exactly what its doing
              Xbox 360 - Drive won't close! - YouTube
              • tkm18
                • Aug 2009
                • 158
                Yes, ejects and closes with the buttons on the ck3i. When attached via sata to the xbox.
                Took it and flashed back to stock, still the same.
                • cunny
                  • 4915
                  Can you post up jungleflasher logs
                  And have you tried clearing the xbox cache
                  • tkm18
                    • Aug 2009
                    • 158
                    Will hook it up and vendor it, read it etc and post the results later when i get back on my desktop.
                    Ive tried every 'fix' on youtube and non of them work.
                    Im 99% sure its mobo related as once i get it hooked upto my computer and the xbox, the ck3i ejects and loads the tray no bother, not sure about JF, will try later.
                    Also ive noticed my lazer doesnt flash when ive got the drive in the xbox, lid off the drive, and its staying open.
                    Totally flung me this one.
                    • tkm18
                      • Aug 2009
                      • 158
                      JungleFlasher 0.1.89 Beta (284)
                      Session Started Wed Nov 23 21:15:14 2011
                      This is a 32 bit process running on 4 x 32 bit CPUs
                      X360USB PRO detected, Version 0.18
                      portio32.sys Driver Installed
                      portio32.sys Driver Started, thanks Schtrom !
                      Found 7 I/O Ports.
                      Found 2 Com Ports.
                      Found 4 windows drives C: D: E: F:
                      Found 2 CD/DVD drives E: F:
                      Drive is Benq..
                      Drive is Benq..
                      Sending Magic Keys to Drive on port 0x0000
                      Done!
                      Sending Vendor Intro
                      Requesting Device ID
                      Manufacturer ID: 0xC2
                      Device ID: 0x11
                      Flash Name: MXIC(MX25L2005)
                      Flash Size: 262144 bytes
                      Sending Vendor Intro to port 0x0000
                      Serial flash found with Status 0x73
                      Sending Device ID request to port 0x0000
                      Device ID: 0x11
                      Getting Status from port 0x0000
                      Reading Bank 0: ................
                      Reading Bank 1: ................
                      Reading Bank 2: ................
                      Reading Bank 3: ................
                      Dumped in 9225mS
                      Loading firmware from buffer
                      Inquiry string found
                      Identify string found
                      Drive key @ 0xA020 A968785FCB857735717D514D417F0D50
                      Firmware Osig: [PBDS VAD6038 0442]
                      Firmware is: Stock
                      Key database updated
                      Loading MTK_Flash source file
                      Sending Vendor Outro to port 0x0000
                      Drive is Benq..
                      Now after a wee bit of messing about, ive discovered the tray wont open because of the top magnet. whens theres contact, the tray sticks.
                      As for the not staying closed issue, not idea, drive worls spot on when hooked upto my pc and ck3i, ejects and loads no bother, unless theres contact between the 2 magnets.
                      • Fellianis Wig
                        • 427
                        I doubt the motherboard is the cause its a faulty drive deffo its a common fault apparently I bought a 360 from game a while back and it started doing that as you describe it wont stay in no matter what.
                        To cut it short you need a new dvd drive
                        • tkm18
                          • Aug 2009
                          • 158
                          Will give that a try, but i cant figure why it works ok with the ck3i and not the xbox.
