Hitachi LT2
    Hitachi LT2
    Bit of a strange one this,when i try and flash my Hitachi 79 to LT2 it shows up as being flashed with 1.91 in Jungleflasher and wont play the XD3 discs.
    If i use the latest JF, it shows the firmware as 2.0 but wont flash it, it says can't open file. I go back to earlier versions of JF and it flashes but shows as 1.91 still.
    Anyone else had this problem?
  • martiboy
    • 541
    Hitachi 79 lt2 has a problem and will be fixed soon
      I read that m8 but it doesn't appear to be the same problem that i have.
      • cunny
        • 4915
        Did you use the CFW i sent you? If so await the fix. There are issues with 79 as said.
        I checked the CFW with JF and showed LT2.0
        From table on c4espeaks
        XGD3 fix for Hitachi 79.
        • cunny
          • 4915
          According to c4e speaks the fix is released LT+ v2.0b RELEASED
          c4eva Speaks! | automated irc logs, updated instantly whenever and wherever c4eva speaks
          LT FW
          JF
            Still no different here . If i use the latest JF an try to reurn to stock it says "can't open file" and that's as far as i get.
            If i use an earlier JF i can return to stock no problem but when i load the latest firmware it says it's version 1.91 and not 2. When i proceed with the flash it wont play the xdg3 discs. I get play game and the screen goes black like it's going to start but goes back to the play game screen.
            I'm running windows 7 on a newly formatted pc. Anyone else hear of this problem ?
            • cgscott
              • 3513
              I will flash a hitachi later and have a look BD. Report back soon
              Patience is a virtue.
              • cunny
                • 4915
                Cant flash any hitachis as dont own any but willing to look at your files with JF if you send them me
                And could you post your jf logs. Dont forget I deleted your via drivers from system32/drivers when I flashed your liteon
