Chnage Liteon Drive to BENQ?
  • DBTraitor
    • Feb 2011
    • 616
    I have a xbox using liteon drive. Is it worth to replace the drive to benq since its easier to flash and I dont have to buy CK Kit , CK Probe etc
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
  • cunny
    • 4915
    You would still need to buy probe ect to dump key plus spoofin of drives is a no no
    • willywonker2010
      • Mar 2010
      • 449
      whats the fault with your real drive
      • willywonker2010
        • Mar 2010
        • 449
        and has cunny sed no spoofing liton
        hack your real drive
        • DBTraitor
          • Feb 2011
          • 616
          I seen the tutorial on youtube on flashing for liteon, it seems complicated which I need to get the probe or something.
          Benq only uses a SATA cable correct?
          • cunny
            • 4915
            The actual flashing of a phat liteon is easy. The obtaining the key is easy with the correct equipment. The probe v3 will do this. You can watch as many tuts as you like. Either buy the equipment or pay someone to do it for you and do the flashing yourself. Its not to differant from the benq
            • dragazar
              • Apr 2011
              • 59
              i flashed a liteon the 1st time the other day, its the same as any other except you hold the probe on a point when u press a button, easy as cunny said you have to hack it if you want to change the drive and if you get a new drive get the same one that you have now if you want to go onlne
              Click thanks if i helped by asking a good question or helped
              • cunny
                • 4915
                Spoofing of drives ain't supported in new dashboards. Liteons are easy once you have the key. If OP dont want to pay for a ck3 + probe then he should send it to someone who can do it and supply him with the dummy.bin so he can do his own updates
