problem with new dashboard
  • georgebourne
    • 5
    Got new dashboard on xbox360 also 3.0 flash and ran games through abx1.6 but now I?m getting this disc is not supported. all the older games and kinects work perfect but the new ones like saints row won?t work it tries to read the disc and the picture of saints row shows in the reading disc but still getting this disc is not supported. also sometimes it might say clean disc
    And yes I am using a ihas 244 b DVD writer I have heard about some bin file that was put in the new dashboard don?t know how true this is
    Any help would be much appreciated
  • KDC
    • Sep 2009
    • 177
    Are you sure you have it flashed with latest lt+ 3.0 firmware? Sounds like you may have older firmware on drive.
    Neil Francis Lennon: "The only way a title is tainted is if you've won it and you cheated to win it."
    • georgebourne
      • 5
      dashboard
      yes got the firmware on i read some where that new dash has a bin file put in it for the AP25 but now much more about it
      • KDC
        • Sep 2009
        • 177
        Yes but dae.bin data changes on new dash should'nt be an issue with lt+ 3.0. All you should have to do is run iso through latest abgx which will patch the topology files and reburn.
        • georgebourne
          • 5
          dashboard
          patch the topology files and reburnt done all above
          thanks by the way for your replys its much appreciated
          also using verbatim mkm-001 or mkm-003 discs
          money going down drain
          • ezzda1
            • 172
            try installing it to the hdd first,
            if it doesn't install, test the disk with kprobe2 and check it burned correctly, chances are it didn't.
            Kprobe Liteon Burn Quality Testing Tool - Team Xecuter
            test guidelines
            XGD3 Quality Test Guidelines - Team Xecuter
            if your test shows the disk isn't within the parameters play with the imageburn settings.
            tips for imageburn settings.
            GENERAL XGD3 - MKM003 (MIS) Settings & Burn Guide as conducted by the author of IMGBURN - Team Xecuter
            • martiboy
              • 541
              You need to recheck your fw on your drive. It sounds like you dont have the latest fw loaded. If you have your jf log could you post it. Also what drive are you trying to play them on
              • djjwdubz
                • 1011
                try this, abgx don't work for me. http://www.digital-kaos.co.uk/forums...atches-249106/
