problem with 6421
  • ken9
    • Feb 2010
    • 52
    problem with 6421
    cant get card to work i pluged sata cable straight into computer and it picked benqdrive up but when i press to read it it says invalid status oxf3 i get nothing when i put sata cable into pci card thanks for looking
  • cunny
    • 4915
    i recomend removing the drivers also power off then on after sending a device intro to the drive.
    For all info refer to Jungleflasher TUT
    • ken9
      • Feb 2010
      • 52
      right got card working now stuck on when i open target f/ware im getting a warning saying 0800f/w should not be used in a console it is for external use only ,do i have to unwrap files thanks
      • cunny
        • 4915
        0800 fw is for ripping games, if your not ripping games THEN THIS FW SHOULD NOT BE USED.
        You will need to read then spoof then write the fw.
        All info in the JF guide.
        • ken9
          • Feb 2010
          • 52
          to late cunny ive done it .how do i get firmware back on ive loaded jungle flasher agaian and pressed read now it says loading mtk flash source file what next ? thanks for getting back
