ihas124-b flashed but no games boot !
  • dave11674
    • 2025
    hi guys
    wondering if any1 can shed some light on this matter for me
    on my old pioneer the games burn fine and work fine in teh 360
    i decided to goto ihas as my boy wants to play online
    so i followed the tut and did exactly what it said to the T
    in regards to updating and flashing the drive
    i ran the update first - currently up to date so i didnt flash anything and didnt reboot.
    backed up my files and flashed the ihas firmware for my dirve. (didnt reboot either)
    (will not rebooting make a diff to the burns ive just done ? and cause them all to fail like they have ?)
    ok so i setup imgburn to how it said
    run my MW3 thru abgx and level 3 repair
    it fixed the topology and verified at end
    xbox 360 is up to date on latest firmware
    drive is on LT v3
    so i chose its .dvd file in imgburn and away it went @ 4x OPC on <think it was OPC
    ok and so verified after a burn. (using verbatim MKM003 i think they are)
    stuck in drive and disc is unplayable
    ive tried about 5 games now all are doing same
    tried at diff speeds 4x & 2.4x with OPC off
    tried on cloneCD and same again
    on a side note i had a MW3 burnt from my pioneer with fixed topolgy data.
    this has worked fine in LT3 drives in the past but wont run in this console !!!
    bad flash on this drive may b ???
    can any 1 help me here my little boy is ready to set about me now
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
  • cunny
    • 4915
    Have you tried any non ap2.5 games? Tried games like Need For Speed Hot Pursuit?
    Could be your ABGX Settings, Xecuter did a Quick Settings Guide abgx360 v1.0.6 - Quick Guide & Settings - Team Xecuter
    Try 2.4x or check your burns using Kprobe Kprobe Liteon Burn Quality Testing Tool - Team Xecuter
    Any thing else you need just post
    • dave11674
      • 2025
      thanks cunny i knew it would be you who answered
      i did try an old game and yes it booted
      i have just now flashed my ihas back to stock using the update tool
      same version it stated but who cares
      rebooted
      then flashed it again with ihas "special" firmware
      rebooted
      im just this second about to reflash teh 360 drive to make sure
      then i know my sheet is spot on
      done hundreds of flashes and never had this problem
      its since i stuck this ihas in my pc
      the pioneer burned just fine
      dave
      Tools owned.
      AVDI commander.
      Dashfixer orig.
      Dashfixer clone.
      Fiat km tool.
      Opel km tool.
      Ford KM tool.
      Op--com colne.
      Lexia & PP clone.
      • dave11674
        • 2025
        ok update i followed first tut and found you can ctrl +s to save ur settings cool didnt knwo that learn somethgin every day how minor it may b
        ok so onto the kprobe read of my disc now
        all seems good. ive reflashed everythgin so will try some more.
        Tools owned.
        AVDI commander.
        Dashfixer orig.
        Dashfixer clone.
        Fiat km tool.
        Opel km tool.
        Ford KM tool.
        Op--com colne.
        Lexia & PP clone.
        • dave11674
          • 2025
          another one for you cunny
          i burnt a mw3 to verbs on pioneer before i swapped it for a tester disc right in my LT3 flashes i do.
          this disc works mint in other machines !!!!
          but will not work at all in this machine either
          ive reflashed it with LT3
          and reflashed my other drives
          doing MW3 at 2x now
          see how this one fairs
          dave
          Tools owned.
          AVDI commander.
          Dashfixer orig.
          Dashfixer clone.
          Fiat km tool.
          Opel km tool.
          Ford KM tool.
          Op--com colne.
          Lexia & PP clone.
          • cunny
            • 4915
            If these aint been burnt from a Ihas burner then its been truncated. I dint think LT3.0 would bother about it. All XDG3 games should be burnt from Ihas burner flashed with LT max FW to fit the full iso on the disc.
            • martiboy
              • 541
              When you boot it on the Xbox does it say disk not supported or does it say disk authorizing failed
              • dave11674
                • 2025
                says disk not supported.
                ok so reflashed everything
                i burnt a game off at 2x
                still same will not boot
                older games boot fine as do orig games.
                not sure whats going on here.
                i tried the burnt discs in my jtag in dvd explorer it only sees the VIDEO_ts folders
                any ideas ?
                dave
                Tools owned.
                AVDI commander.
                Dashfixer orig.
                Dashfixer clone.
                Fiat km tool.
                Opel km tool.
                Ford KM tool.
                Op--com colne.
                Lexia & PP clone.
                • martiboy
                  • 541
                  When you put a blank disk into your ihas burner. Go into img burn and does it show up as having somthing like 8.7gb instead of 8.5 blank space. I can't read the tut just now because I'm on my phone but I'm pretty sure the pc needs to be rebooted at some point during the burner max firmware
                  • cunny
                    • 4915
                    Also after reboot run the burnt disc through ABGX and post results
                    • dave11674
                      • 2025
                      yes blanks are showing up as 8.7gb yes
                      ill run the disc thru abgx and post up in 2 mins
                      t6hanks guys
                      dave
                      Tools owned.
                      AVDI commander.
                      Dashfixer orig.
                      Dashfixer clone.
                      Fiat km tool.
                      Opel km tool.
                      Ford KM tool.
                      Op--com colne.
                      Lexia & PP clone.
                      • dave11674
                        • 2025
                        \\//\\//\\//\\// _ |_ _ \ \/ /_ _ _ \\//\\//\\//\\//\\//
                        //\\//\\//\\//\\ (_||_)(_|/ /\ \_||_ | | //\\//\\//\\//
                        ------------------------_|------_||_||_|--v1.0.6-
                        [http://abgx360.net]----
                        Checking for updates to abgx360.dat...
                        Server file abgx360.dat no newer than local file - not retrieving
                        Checking Game
                        ISO: "ATAPI iHAS124 B AL0S <2011/08/11 10:09> [RAID] (G"
                        Layerbreak: 2133520
                        Files in ISO: 218, Folders in ISO: 1
                        Total bytes used: 8112921882 (93.66%)
                        Game appears to have random padding
                        Checking default.xex
                        Original PE Filename: iw5sp_ship.exe
                        Original PE Timestamp: 2011/09/19 11:23:22
                        Min Kernel Required: v2.0.13599.0
                        Game Name: Modern Warfare? 3
                        No Avatar Awards
                        Achievements: 50 Achievements totaling 1000 Gamerscore
                        XEX CRC = C9F701C6
                        XEX Media ID: 05BD7797B9F7170E3157F8A6-30775D59
                        Region Code: 0xFFFFFFFF
                        Region Free!
                        Checking topology data
                        Querying the online database to find the appropriate verified data to use...
                        Topology information was downloaded successfully
                        Looking for TOP_XGD3-DID-F87A804E_v1.sha1 in the online verified database
                        Server file TOP_XGD3-DID-F87A804E_v1.sha1 no newer than local file - not retrieving
                        Topology data is currently verified
                        Checking SS
                        Timestamp of Authoring: 2011/09/20 00:00:00
                        Timestamp of Mastering: 2011/09/28 08:57:20
                        SS Version: 2 (trusted)
                        SS CRC = 20E71B4E (RawSS = A5330260)
                        SS Media ID: 05BD7797B9F7170E3157F8A6-30775D59 (matches game)
                        SS looks valid
                        Checking DMI
                        Timestamp of Authoring: 2011/09/20 00:00:00 (matches SS)
                        DMI CRC = 290D3054
                        DMI Media ID: 05BD7797B9F7170E3157F8A6-30775D59 (matches game)
                        DMI looks valid
                        Checking PFI
                        PFI CRC = 26AF4C58
                        PFI matches known data (XGD3)
                        Video partition found
                        Video CRC = F3CBE200 (V0 = DFFD5BC3, V1 = 563325D0)
                        Basic Stealth check passed!
                        Starting Verification
                        Looking for 20E71B4EC9F701C6.ini in the online verified database
                        Server file 20E71B4EC9F701C6.ini no newer than local file - not retrieving
                        Using 20E71B4EC9F701C6.ini (350 bytes)
                        Video CRC matches
                        V0 CRC matches
                        V1 CRC matches
                        PFI CRC matches
                        DMI CRC matches
                        SS CRC matches
                        Xex CRC matches
                        All Stealth CRCs match (Game CRC was skipped)
                        Stealth was verified but game data wasn't
                        Tools owned.
                        AVDI commander.
                        Dashfixer orig.
                        Dashfixer clone.
                        Fiat km tool.
                        Opel km tool.
                        Ford KM tool.
                        Op--com colne.
                        Lexia & PP clone.
                        • dave11674
                          • 2025
                          im letting it do a data verify now. that was the initial checks
                          dave
                          Tools owned.
                          AVDI commander.
                          Dashfixer orig.
                          Dashfixer clone.
                          Fiat km tool.
                          Opel km tool.
                          Ford KM tool.
                          Op--com colne.
                          Lexia & PP clone.
                          • dave11674
                            • 2025
                            guys my mw3 failed verification
                            so the next question is why is it failing as teh iso is verified !!!!
                            also im just testing a black ops too
                            that has just booted on a hitachi 47dj
                            but will not boot on his new slim 1071 drive
                            could it have somethgin to do with the slim 1071 drive!!
                            im thinking no but everythign is a possibility to me now
                            mind u older non ap25 games boot fine
                            whats my next step guys
                            its deffo not writing them correctly at some point
                            dave
                            Tools owned.
                            AVDI commander.
                            Dashfixer orig.
                            Dashfixer clone.
                            Fiat km tool.
                            Opel km tool.
                            Ford KM tool.
                            Op--com colne.
                            Lexia & PP clone.
                            • cunny
                              • 4915
                              I think you need to adjust your advanced settings for the burner. I will post mine when I can get on pc
