hi, i am just having a potch around with this drive, i think i flashed it wrong, i have the correct key for it, but its like the drive is dead or something, it will not load in bios before computer starts up so , went in jf did a lte on Erase command, managed to get status 72 after a bit of fidgeting with power cycle, and i got it in vendor mode, when i read it it says unkown flash, i pressed intro device and tried read it again and i h ave got i t now to read erase and write, but everytime i try to write firmware it fails to verify abny ideas what i did wrong to it :S thanks
EDIT :- Here is my JF info its weird it says its failed like before but this time it said "verfiied by c4eva now i have played with it more"
Now i am getting this message Write Verify Failed !
Sending Vendor Outro to port 0xC800
Drive is Lite-On..
Stage 1 failed
Ok so i noticed that the drive ejects now, so i rebooted the pc and the bios has recognised the drive now so i proceeded to flash again and it worked
Happy days
Flash Verification Test !
Reading Bank 0: ................
Reading Bank 1: ................
Reading Bank 2: ................
Reading Bank 3: ................
Drive type Un-determined
Key found in KeyDB at record (- N/A)
Key is: HERE BUT I DELETED from post
Key has been tested and verified, thanks C4eva !
Drive is Lite-On..
Stage 1 failed
Happy days
