noob needs flash slim xbox
  • jaaa1976
    • Oct 2011
    • 16
    Hallo.Im buy xbox 360 slim.DVD drive inside is Lite-on Model; DG-16D4S Winbond
    FW;ver; 0225 HW Ver; A0A0 ,dashboard 2.0.14719.0
    Please ..which firmware I can use for flashing and which cables I need to buy?It is possible to flash vith laptop or I have to buy pc?Thanks
  • shankill2012
    • Feb 2010
    • 285
    Dont think you can flash that drive mate the chip on the pcb is locked and cant be written to, i have the same drive but i bought an "unlocked replacement pcb" board from an xbox modding site and replaced the locked one and then you can flash whenever you want, also google the " kamikazee hack" if you are confident enough to tinker with xbox.
    • dragazar
      • Apr 2011
      • 59
      there are some good guides on team executer forums just do a search for slim tutorial
      Click thanks if i helped by asking a good question or helped
      • jaaa1976
        • Oct 2011
        • 16
        I found this quide...Liteon DG-16D4S 0225 (Slim) Unlocked PCB / Pro Kit - Step-By-Step Guide - Team Xecuter
        I dont know if this helps..
        • cunny
          • 4915
          • jaaa1976
            • Oct 2011
            • 16
            Thank you for help.So im going to do kamikaze hacks vith soldering iron.
            If Im will be succes vhich firmware i can flash for playing backups games ?thx.
            • jaaa1976
              • Oct 2011
              • 16
              Can I extract key vith this homemade probe?..eBay - The UK's Online Marketplace
              • cunny
                • 4915
                You don't need a probe to get the drive key. Follow the jf tutorial
                Sent from my GT-I9000 using Tapatalk
                • jaaa1976
                  • Oct 2011
                  • 16
                  Do I need to buy
                  X360USB PRO + CK3 MINI MEGA BUNDLE #3 http://www.ck3.co.uk/x360usb_pro-ck3...-bundle-3.html
                  for extract key? or how I can do it?thx
                  • martiboy
                    • 541
                    Both those tools would be a big help. Before you ATTEMPT the kamakazi you will need to extract the dvd key. As cunny has already said follow the jungle flasher tut. It will explain how to extract your dvd key using the x360pro and the ck3i.
                    • jaaa1976
                      • Oct 2011
                      • 16
                      Ok.so vith this homemade probe is not possible extract key.If I decide risk kamikaze vithout key and I will not be successful...can I buy after chip from Xbox 360 Slim Lite-on DG-16D4S 9504 272 225 0401 1071 (MT1339E+SPI-MX25L2005MC) | eBay
                      change and extract key after.
                      • cunny
                        • 4915
                        What i cant get here is that you aint read what we told you to read. No probe is needed to get the key from the drive. Use the slim key function in jungleflasher. Again READ the JUNGLEFLASHER TUTORIAL.
                        All you will need is in this.
                        As for replacing the SPI to that, you would STILL NEED THE DRIVE KEY FROM THE ORIG SPI. This takes 2 mins with jungleflasher. Once you have the drive key, do what you like. Kamikaze the PCB, replace the SPI or buy unlocked PCB
                        • dantetimoc
                          • Mar 2010
                          • 420
                          ypu dont need any special tool for kamikaze you chip on Lite-on Model DG-16D4S. just connect your drive to a computer power suply ( +3.3, +5V, +12V and GND) ( i use external power suply because the xbox power will go off after aprox 5 minutes )
                          you will find DVD pinout in this document:http://dwl.xbox-scene.com/tutorial/X...HandC-V1_4.pdf
                          Power on you you drive connected to a usb to SATA for 10-15 sec. then move the sata cable to computer Sata port ( drive still powered) and drill it. use unlockspi.exe ( but first use jugleflasher to determine on witch port is your dvd drive on computer, ex: CC00 in my case )
                          Autotuner- Kess 3, genuine master tools.
