making lots of coasters with my lite-on help please
  • the goat
    • Mar 2010
    • 122
    hi all
    just flashed an old xbox360 hitachi 47 drive that i got for my lad with LT2
    got a pre-flashed lite on 124b from ebay to write discs
    followed guides on how to download/write, using xbgx imageburn, but keep getting unrecognized disc error in xbox
    i have burnt 2 games with my old pioneer f/street, & golf 13, both of these work ok,
    the ones i burnt with lite on 124B all come up unrecognized disc,
    i've tweeked laser pot from 3.4 to 3.1, made a slight differences in that it see's something on copied ssx disc
    any tips please,
    be easy with me as i'm an old dinosaurs ( both old and dinosaur are true)
  • cunny
    • 4915
    I had the exact same issue recently with a 47dj. I just replaced the laser and it worked first time
    • the goat
      • Mar 2010
      • 122
      i've taken some discs to work to see if anyone has flashed xbox and get them to try the discs i made to see that they work
      if its a laser change i may look at getting another drive to replace hitachi,
      any thoughts
      • ezzda1
        • 172
        just replace the laser or change drive for the same make / model.
        to make sure the disk is good: download kprobe2 from here
        Kprobe Liteon Burn Quality Testing Tool - Team Xecuter
        the results should be like this or better to be a good burn,
        XGD3 Quality Test Guidelines - Team Xecuter
        if it passes the test it will be a dodgy laser.
        • the goat
          • Mar 2010
          • 122
          laser picked up another disc yesterday
          i've attached a usb hdd and installed the games on there
          thinking i may just try to tweek laser down to 2.9 ohms and see what that does
          if i need to change the laser anyway can't do that much damage
          think with my old eyes maybe better to buy new dvd drive instead of trying to fit a laser
          as its an old hitachi 47 need to cvheck what i can replace it with
          • cunny
            • 4915
            This is the laser I purchased
            Hitachi / Samsung Laser SF-HD63 *NEW* - ModTraders.co.uk (but check yours model number is on the laser itself)
            Check though on the model number. POT Tweaking does not always work with lasers. I have tried a few only only ever seen marginally better reading.
            If you purchase a new laser just remember to remove the anti static points on the laser duriing instalation
            • the goat
              • Mar 2010
              • 122
              thanks for the link
              i'm thinking its easier to get a new drive, for another ?15 i don't have the worry of striping and rebuilding old drive
              5 yrs ago i would have done it, but now need a magifing glass to see these little wires and solder points
              • the goat
                • Mar 2010
                • 122
                just had a look on ebay
                Lite-On DVDrom Drive DG-16D2S (Xbox 360 replacement DVD drive) | eBay
                this place it just down the road to me,
                can i replace my hitachi 47 with a lite-on ?
                i've got the hitachi key and origanal firmware as i flashed it last week
                • cunny
                  • 4915
                  You cant replace a hitachi with liteon, this is called spoofing and its no good anymore. The anti static points are easy enough to see and remove. Take about 30 seconds with a soldering iron. Here's a tut
                  Tutorial - Hitachi - Scenyx Entertainment Community
                  Also did the backups work in another xbox?
                  • the goat
                    • Mar 2010
                    • 122
                    i could view your link from work, (blocked0
                    so i'll look to night
                    • the goat
                      • Mar 2010
                      • 122
                      new laser fitted looks like that's fixed it
                      plays lots of discs now
                      • cunny
                        • 4915
                        The thanks button goes a long way also ya know
