Xecuter RGH2.0 Official Release
  • cunny
    • 4915
    Team Xecuter RGH2.0 For CoolRunner Rev A and B
    We were not quite ready to release this due to it's unstable boot times on older glitch hardware, but as our code was leaked from a team member AGAIN we had to release this due to another team stealing the code and claiming as their own work. They were even too lazy to change any of the patches to make it look like their own ***8211; they are 1:1 same as our original sources. Super lame. It seems some teams think this is the Wii or PlayStation scene and you can act like this. They don't even give credits to cOz for his SMC patcher ***8211; because they didn't even know that code was from him of course.
    We don't want to get dragged down into bullshit scene politics ***8211; most of you won't care anyway, but a lot of guys work very hard on this stuff only to have it stolen with no effort and no credits is just sad. Anyway***8230;***8230;
    The Xecuter RGH Development Team are pleased to announce the official release of the RGH2.0 hack for all CoolRunner Rev A and Rev B dev boards. All Phat consoles have now been defeated and are totally glitch-able without having a previous NAND dump or CPU KEY (the same applies to Slim Trinity that have been updated to 14717/14719).
    We have included all of the build.py and xebuild scripts for your convenience. Please give the correct credits if you use our work.
    Xecuter RGH2.0 Features introduced:
    Hack now works on new CB's (14717/14719 update)
    Hack now works with all Refurbished Split CB's (4577, 5772, 6752)
    Zephyr CB 4578, 4575, 4577
    Falcon/Opus CB 5771, 5772, 5773
    Jasper CB 6750, 6752, 6753
    Trinity (Slim) CB 9188, 9230
    To confirm, we can now glitch Phats with any kernel and any bootloader. As soon as you have your CPU KEY, and you are using an Xecuter DemoN you will ALWAYS be able to switch to a fully hacked NAND and it can never be stopped no matter what update you apply and no matter which efuses are blown !
    Technical Info
    In the slim boot chain the 2nd bootloader (CB) is split into two pieces. The first part simply starts encryption and loads the second part, which does fuse checks and all the things that the old single CB did. By glitching the first part (CBA), we take control of the system before the fuse checks occur and can patch them out. The slim bootchain has always used this layout and some groups have even tried bringing the slim CBA to phat and using the old single phat (RGH1) CB as CBB. Glitching this way will work if you set it up right, but there are actually phat xboxes that already have their own split CB boot chain which were mostly ones that had been refurbished (CB 5772, 6752, 4577).
    What we have done is simultaneously find glitch timings for these refurbs, dump their cpu_key, decrypt the boot chain, and port it to run on every other phat! This means that on phats we can now glitch before the fuse check and thus have an unpatchable hack just like trinity!
    New Xecuter CoolRunner v2 Hardware
    There have been many obstacles to cross with this because CBA glitching does not behave quite the same as CB glitching. The Coolrunner revisions A&B will glitch for RGH2.0 but results will vary and with some, boot times can be worse than trinity and with others they may be instant. These boot times are unacceptable and this is why we have spent the last few weeks designing a new glitch chip that will solve all these problems and will even help with trinity and corona boot times
    New Xecuter CoolRunner v2 Upcoming Features:
    Corona support
    Much better glitch times for RGH1 and RGH2
    All-in-One code for all versions
    Demon integration
    Level shifted POST output
    ***8230;and much more
    Development is almost complete ***8211; find an image of the CR v2 dev unit in this release pack.
    Building an Image
    With RGH2, a cpu_key is necessary for building the NAND image. The reason for this is because cpu_key encryption starts at CB, and in RGH1 there was only one CB which meant that CD was encrypted with cpu_key but CB could be "zero paired" which meant that the cpu_key would not be applied. When split-CB was added, they started the encryption at CBA and removed the zero pairing option, which means that cpukey encryption on CBB is mandatory. Because of a vulnerability in the way they use RC4, if you have a stock NAND image that already has a CBB encrypted on it, we can derive the keystream used in that image because we know what the CBB looks like decrypted (we have already decrypted that version before). Because of this, we can embed the older vulnerable CBB into the NAND image using the keystream.
    Bottom line is, after the 14717 update they turned all phats into a split CB boot chain but using unglitchable bootloaders. We can still glitch these boxes even when we don't know the cpu_key because we can use the "XOR hack" to embed the RGH2 bootloaders. For older images (pre-14717) we need the cpu_key to encrypt the new loaders because there is not a CBB already in the image that we can derive a keystream from.
    Once the cpu_key is retrieved, you can always build a NAND image for RGH2'ing your machine. You can flash back to stock, update, even burn all your fuses and you would still be able to run RGH2.
    For building a xell image, read the readme in XECUTER_RGH2_Xell.
    For an xebuild image (if you have your cpu_key already) browse to XECUTER_RGH2_Xebuild.
    Instructions
    First wire up your Xecuter CoolRunner according to the diagram provided. RGH2.0 Requires that you either already have your cpu_key or you are on dashboard 14717/14719. This means that if you do not have your cpu_key, you must run xell first to retrieve your fuses.
    COOLRUNNER CPLD PROGRAMMING
    The XSVF files are located in \xsvf folder. Start with the xsvf recommended below, however every xsvf should run on every motherboard, but one of them will work best for your setup.
    Falcon/Opus: Program either TX_RGH2_B.xsvf, or TX_RGH2_C.xsvf
    Jasper: Program either TX_RGH2_A.xsvf, or TX_RGH2_D.xsvf
    Zephyr: Program either TX_RGH2_D.xsvf, or TX_RGH2_C.xsvf
    Please enjoy this release and report any interesting tweaks you may find. Our forums at Team Xecuter - Rockin' the Box Since 2002 offer excellent support and we would be glad to help and receive feedback from you.
    CREDITS:
    If you are going to use RGH2.0 please give credits to the Team Xecuter RGH development Team. Don't be lame and try to claim the work as your own.
    Thanks to Tiros & GliGli for their original RGH work.
    Thanks to cOz for his universal SMC patcher.
    Thanks to all the Xecuter developers and official testers. You know who you are.
    Thanks to Ubergeek for the diagram.
    Thanks to the asshole who leaked our code for others to steal and claim as theirs. Super lame.
    Xecuter RGH2.0 Official Release | Team Xecuter
    Xecuter RGH2.0 JED Files & Other Updates | Team Xecuter
