BF3 wont work
  • m9g
    • 704
    BF3 wont work
    Hi
    A few weeks ago i started getting a "cant read disc" with bf3 which did work , i have lt3 and burnt with ihas burner, other discs work fine, I re-burnt it yesterday running through abgx first and all patched fine and yet again getting same error
    I have an original mw3 and made a backup of it and works fine.
    DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
  • Bann32
    • Oct 2011
    • 518
    Assuming its possible id tell Nero or something simular to verify the data. But some discs are just like that in certain drives used to be a lot worse with cd's...
    • cunny
      • 4915
      Cant you guys search a bloody forum
      • m9g
        • 704
        Thanks but not a prob with anything I was doing as have burnt many discs before and usually I do use the search forum function first, was just asking if it was a bf3 thing.
        Had updated to imgburn 2.5.7, went back to 2.5.6 and worked fine, cant say if it was 2.5.7 or just a bad disc.
        Topic closed
        • cunny
          • 4915
          Topic closed
          From experience AONE discs are shite for xdg3 burns. Reason being is the dye is shite on the outter ring of the disc. This is why verbs work allot better for these burns.
          If you run a a aone burn through kprobe and look at the shite results you will get compared to a verb.
          The other issue could be weak laser in the burner. If your doing allot of burns then this can cause it too.
          I for 1 am on my 2nd burner
          • m9g
            • 704
            Thanks cunny, yeah have always known about the quality issues and settings changes with the aone discs - I never use anything but verbs
            • douglaswalkers
              • May 2012
              • 8
              Battlefield 3 is a best action game which full of warrior effects. It view the different from civilian war which fully destroyed to the land. There are more than crowd about warrior sounds and effects.
              • m9g
                • 704
                WTF!!!!!!!!!!!!
