Verification Failure?
  • toe471
    • 254
    Ran the Sniper Elite V2 through Abgx and its coming up with the:
    There is no verified rip of Xex CRC 52DC2447 in the online database.
    Someone also said that when you go to play this game it asks you to do a Update before playing which may bugger the Xbox up. I only had my drive flashed about 3 months ago may I add.
    I have only checked this game through Abgx and not burned it yet as I have come across this problem?
    Any help guys much appreciated!!!!
  • felix11
    • 151
    The reason it fails to verify in abgx is there is no verified rip in the abgx database to verify it against. This is normal for a new game as it often takes a while for a verified rip to be posted.
    The game needs dashboard 14719 (the latest) to work. Strictly speaking, you should flash back to stock before applying any major upadate, but there is no info to suggest it is unsafe to apply this dash update with a flashed drive. If however you play online I would advise you to flash back to stock first to be on the safe side.
    • m9g
      • 704
      there is another post regarding the same game, just goto abgx website and click on verified, will save you time running it through abgx software to confirm its not verified.
      DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
      • toe471
        • 254
        thanks for the replys guys!
        I heard about that dashboard 14719 for the game to work but would it still be ok to do an update through xbox live or just leave it?
        What do I have to do when I go to the Abgx website, can you also get a verification from there without reling on the actual stage of running the program?
        • m9g
          • 704
          Yep as i mentioned go on abgx website and click on verified, it will list all the games that are in the database, if its not there then dont bother running through abgx software
          Sniper Elite v2 not there at the mo - but i'm sure it will be soon, fingers crossed
          • toe471
            • 254
            cheers for that M9g!
            I had a look before and like u say its not there, that means I cant play for a bit now
            How about manually inserting something????
            • cunny
              • 4915
              There is nothing to manually insert? You have to wait for a verified rip.
              If you want to play this game, get a jtag, remove updates and play from GOD.
              I think it could be a new wave game (as it has latest dash on it) This could be delaying it getting verified
              Or just wait
              • toe471
                • 254
                ok will prob wait, its been out a couple of weeks now, they are taking there time!!
                • m9g
                  • 704
                  Hopefully the wait will be worth it, failing that you could always go out and buy it
                  • cunny
                    • 4915
                    i was gonna say that
                    • m9g
                      • 704
                      • toe471
                        • 254
                        Just an update here guys!
                        Sniper Elite V2 Has still not been verified for some reason, I've just checked on the abgx website and its still not up there, its been like nearly 2 weeks now and still nothing??
                        Have they forgot about this game?
                        • cunny
                          • 4915
                          Its looking like a new wave. Hold on it will be there soon enuf
                          • m9g
                            • 704
                            ^^^^^^ whats the top section of your reply gotto do with xbox360 - post in the right section please hahaha
                            • felofer
                              • May 2012
                              hola que hago para descargar
