play movies on xbox
  • ned
    • 25
    play movies on xbox
    Very new to x box ,how can i play d/l movies from my computer through my xbox and on to my tv.Please any connections ect , i don't have wireless only wired and would like to know how to do this in very simple terms. Many thanks
  • cunny
    • 4915
    Are they both networked up?
    If so then this will do the trick TVersity - Home
    • chroma
      • 1976
      set up windows media player 11
      add everything you want to play into your library (i have set a folder on my F:\ drive as my library)
      power up your xbox and try accessing computers on the network, it should show up in wmp11 and you just need to allow access.
      make sure that your firewall is configured to allow access too and everything should play fine.
      He who laughs last thinks slowest.
      • djjwdubz
        • 1011
        or you could connect your xbox360 to the internet burn your movie on to a dvd or cd if it fits then when u put it in the xbox drive it will say you need a update to play your movie then when it has updated then open the drive and close it then it will start playing hope i have helped you mate
        • mickydibble
          • 2166
          you can play avi.movies of usb flash drive through xbox...m
          • ned
            • 25
            Not sure how to network up,ip address failed keeps coming up
            • Jamone
              • Mar 2009
              • 4
              You can convert the movie into a mp4 which should play. ALso heard WMV but not got that to work.
              There is free software to convert avi to mp4.
              • cM iPro v3
                • 213
                this is the same as playing music off your xbox console if you put the film you want on your computer and then put it on the shared drive and play it off the shared drive of the xbox console
                The statement below is False
                The statement above is True
                Which one is correct
                I am the fish geek
