xbox 360 xgd3 games wont play
  • daddi345
    • Jun 2012
    • 5
    hi i wonder if any 1 can help !
    i have a flashed xbox 360 which was working fine running lt2.0 firmware, i downloaded the new ghost recon and changed the iso to play on lt2.0.
    since my son did the disc update it now wont play most of the new games it used to play can any 1 help or is it just a matter of upgrading to lt3.0 ?
    all help appriciated
  • cunny
    • 4915
    Could be a burning issue. Id still update to 3.0 as saves patchin that aint live safe. Check bur s with kprobe an post media used + results
    • mickm1
      • Feb 2011
      • 46
      Not an expert but i believe u need an IHAS mode b drive m8, various models available but LiteOn seems to be the best along with pioneer.
      • cunny
        • 4915
        Yes u do need a ihas rev b burner. These are actually discontinued.
        • daddi345
          • Jun 2012
          • 5
          sorry to sound noobish but do i need a ck3 kit to flash as before or is there a way around that ?
          • cunny
            • 4915
            depends on drive/situation ect. As much info as you can post helps get the right course of action
            • Marmiek
              • Jun 2012
              just need the overburner and the downgrader like xbc,,,
              • cunny
                • 4915
                If u are on about truncateming then 1 hitachi drives dont support truncated burns and 2 they aint safe as checks could be in the bit of burn u miss off. Do stuff right
