update stopped problem help please
  • eurodrift
    • Jun 2012
    • 23
    hi tryying 2 fix error code 22fb-335a-2800-0f00-c000-0034 as its coming up up date stoopped then givingthis code the xbox hasnt been flashed at all tryed so many updates and still no luck any help would be grateful thanks
  • janobi
    • 1624
    Try updating from USB stick
    • cunny
      • 4915
      Try another game from same wave. I think it's from a pre xdg3 dash so it's trying flash the drive
      Sent from my GT-I9300 using Tapatalk
      • eurodrift
        • Jun 2012
        • 23
        ive try loading from usb about a hundred times i will try another game
        • cunny
          • 4915
          Ive seen this error mainly when drives were not flashed back to stock when updating to the XDG3 fw. Check for drive fw and get another disc with update on. should cure it
          • eurodrift
            • Jun 2012
            • 23
            how do u flash back 2 stock
            • looney2008
              • 16
              in jungle flasher and firmware pack with lt3.0 it normally has a folder that says stock firmware and with post and pre dash folders select the psot folder and use the file inside this is for liteon drives if its a different drive then find the same firmware for that drive then flash back to drive.
              1 read drive with ck3 and usb pro in jungle flasher
              2 when it asks to auto load lt3.0 select no instead choose correct origional firmware for your drive
              3 important click spoof to drive
              4 flash drive then connect to xbox updtae
              5 repeat 1-4 but allow jungleflasher to use lt3.0 this time say yes then flash as befor.
              6 enjoy you legal back ups.
              if you let me know what drive it is i can post the firmware info you need in better detail
              • eurodrift
                • Jun 2012
                • 23
                how do i find out what drive i have as i dont now what 1 i have andsorry 4 the late reply
                • ezzda1
                  • 172
                  you need dash update 13146,
                  download updatespy,
                  UpdateSPY_14719-1.rar download - 2shared
                  select 13146 dash stick it on a usb stick, plug it into your console it should finish the update off.
                  • cunny
                    • 4915
                    No it wont. You will have to do the update from a original game. Once the update process is started from a backup it will look at the drive for the rest
                    sent from my fat fingers using tapatalk.
                    • eurodrift
                      • Jun 2012
                      • 23
                      thanks for al ur help ended up buying a new 1
