Xecuter Corona16 XC2C64A VHDL Source Code
We have added the full VHDL source code for our Corona16 XC2C64A hack. As reported before the limitations of the hardware make it an unreliable glitch ? we have fixed this with the upcoming CoolRunner 3.
We also found the possible reason that Xell doesn't boot with any video. The ref clock changes from 14Mhz to 24Mhz. On Corona it changes to 30Mhz and crashes ? hence no video. This is ref clock for lvds controller on the GPU from lvds hana change sync in hdmi. But if lvds doesn't work, then the gui doesn't work. No doubt the Xell guys will have a fix shortly. In the meantime you can get your CPU Key via Jrunner over lan using Xell ? and you can even use the CK3i or NAND-X USB Update cable to get the CPU Key over Serial ? JRunner will open the COM Port and sniff the key out for you ? we added this a couple of weeks ago
Xecuter Corona16 XC2C64A VHDL Source Code | Team Xecuter
Xecuter DIY Corona16 CoolRunner ? Free Upgrade
PLEASE BE AWARE THAT THIS CORONA RGH METHOD IS NOT TOO RELIABLE AND DOES NOT GLITCH AT THE BEST SPEEDS. THE HACK IS MADE AVAILABLE SO YOU CAN HAVE A PLAY WITH THIS YOURSELF AND SEE WHAT RESULTS YOU CAN ACHIEVE.
THIS IS WHY WE DESIGNED THE COOLRUNNER 3, IT HAS BEEN FINE TUNED USING A MUCH MORE ADVANCED DESIGN AND GLITCHES VERY RELIABLY AND VERY FAST. WE DO NOT OFFER ANY GUARANTEES OR SUPPORT WITH THIS CORONA METHOD.
To get this working on CoolRunner Rev A B or C you simply have to add a 48.000MHz crystal.
If you have Rev A or Rev B remember to remove C15.
It's a bit cheap and cheerful and the hack isn't that good with the limitations of the older gen XC264A hardware but here it is anyway.
The crystal has to be good quality ? not some cheap crappy one as it will not work.
Xecuter DIY Corona16 CoolRunner – Free Upgrade | Team Xecuter
CoolRunner 3 In Production/Free DIY Corona Upgrade/CPU RESET Cleaner/JRPv1 Upgrade /iPhone App for Demon and CoolRunner
It's been just over 2 months since we cracked the Corona and perfected the boot performance along with the new RATER System so you can get the absolute best quality glitch for your money.
The JR programmer v2 is also in production along with a brand new QSB for the Trinity and the Corona.
CoolRunner 3 In Production/Free DIY Corona Upgrade/CPU RESET Cleaner/JRPv1 Upgrade /iPhone App for Demon and CoolRunner | Team Xecuter
